Rear driver side lean
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bassassasin1, Feb 1, 2023.
  1. Feb 1, 2023 at 5:16 PM
    Bassassasin1
    Bassassasin1 [OP] Active Member
    2016 TRD Off-road
    My taco has bad lean mainly in the rear. How do I fix this?
  2. Feb 1, 2023 at 5:21 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Have a fat chick sit in the passenger seat
    Rainoffire, Cushmaat, maineah and 6 others like this.
  3. Feb 1, 2023 at 5:23 PM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    search taco lean and you’ll get a bunch of hits.
  4. Feb 1, 2023 at 5:39 PM
    Bassassasin1
    2016 TRD Off-road
    Ok
    Chew likes this.
  5. Feb 1, 2023 at 5:42 PM
    Bishop84
    Bishop84 Well-Known Member
    Quick run down, its because driver, battery, and gas tank are all on the left side. So the leaf sags first.
    You can put a spacer on to shim it up, but at that point you are buying new u bolts, just replace the damn leaf set.
    OnHartung'sRoad likes this.
  6. Feb 1, 2023 at 5:42 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    You could put in a spacer like this:
    https://www.headstrongoffroad.com/store/p31/HS_1/4"_Top_Plate_Spacer_-_TT05514-TPS.html
    … or put in stronger springs in back. The weight of the gas tank, battery plus driver on the left side tends to throw off the balance a bit on these trucks. I personally just counter-weighed it with a high lift Jack, a spare battery and other tools mounted to the right side. In my case the lean was a lot worse as I also put in a spare 15-gallon gas tank on the left side also.
  7. Feb 1, 2023 at 5:43 PM
    Bassassasin1
    2016 TRD Off-road
    I have 1” blocks in the back already
  8. Feb 1, 2023 at 5:45 PM
    Bassassasin1
    2016 TRD Off-road
    That plate is for the front, mine is in the rear. I have 3” level in front and 1” blocks in the back. It’s really noticeable. About 5/8 to 3/4 “ lower on driver side rear.
  9. Feb 1, 2023 at 5:47 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Measure the difference when your gas tank is empty and when it is full. You have a block, but are you still on stock leafs?
  10. Feb 1, 2023 at 5:48 PM
    Bassassasin1
    2016 TRD Off-road
  11. Feb 1, 2023 at 5:48 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Get rid of blocks and put leaf packs in, or 3 leaf add a leafs.
  12. Feb 1, 2023 at 5:49 PM
    Bassassasin1
    2016 TRD Off-road
    Yes stock leafs
  13. Feb 1, 2023 at 5:49 PM
    Bishop84
    Full set, no one sells 1 leaf anyway, you can get OEM and re-use the blocks, if you haul or tow, get a proper HD pack.
    na8rboy likes this.
  14. Feb 1, 2023 at 7:12 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    don't put gas in it, sit in the passenger seat when driving, and lower the passenger side rear tire pressure. don't bother trying to level it out, you'll just mess up the suspension. and yea, like others said, get rid of the blocks.
  15. Feb 2, 2023 at 12:20 PM
    Spindelatron
    Spindelatron Well-Known Member
    Bay Area, CA
    18 Cement TRD SPORT AC MT
    run driver's side tire pressure at 40psi and passenger side tire pressure at 14psi (s)
    maineah and cryptolime like this.
  16. Feb 2, 2023 at 1:05 PM
    Bassassasin1
    2016 TRD Off-road
    Thanks for the help
  17. Feb 2, 2023 at 1:19 PM
    84-4runner
    84-4runner Well-Known Member
    frank
    Northern Arizona
    2019 tacoma offroad
    intake mods, firestone airbags, campershell, backup lights,
    rather than add a leaf use airbags that are plumbed individually.
    easy leveling. Or drive around on empty and lose a lot of weight
  18. Feb 2, 2023 at 2:12 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    my truck doesn't have a lean and i've been looking for it every day. perhaps the leaf springs start to sag after a while? i think they put heavier leaf springs in the 2021 access cabs, at least in the SR trim. the leaves seem a lot stiffer than my 2020 SR AC which would hit the bump stops driving over train tracks too fast. my 2021 is the complete opposite and rides like a dump truck when empty.
    the 2020 was 2wd and the 2021 is 4x4. maybe they put heavier leaves on the 4x4s.
  19. Feb 2, 2023 at 2:14 PM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    sure this is the easiest and fastest way of fixing it.
    TexasWhiteIce[QUOTED] likes this.
  20. Feb 2, 2023 at 2:38 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Have any of you actual measured the frame to flat ground both sides while this thing is "leaning"?
