Rear Driver's Side Lean is HUGE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tethsojh, Feb 1, 2016.
  1. Feb 1, 2016 at 8:15 AM
    tethsojh
    tethsojh [OP] Well-Known Member
    Quad Cities, IL
    2000 Toyota Tacoma TRD 4WD Extended Cab
    I have a 2009 DC 4wd. It has always leaned about 1/2 to 3/4 to the drivers side. I understand this is almost a given with Tacomas. I have no AAL or TSB. Just stock.
    Over the weekend i put 5100's (set at 1.75) on the front with a Toytec 1/4" spacer on the drivers side. Im happy with the height but now the driver's side rear is way, way leaned.
    Measurements from ground to bottom of fender:
    Front Passenger: 35.5"
    Front Driver: 35.25"
    Rear Passenger: 36.75"
    Rear Driver: 35.50" ****
    What can i do to fix that? The only idea i have is to put a 1" block JUST on the rear driver's side.... Any downsides to that? Any ideas?
    Thanks
  2. Feb 1, 2016 at 8:38 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    no, dont do a block just on one side.
    Make sure you were parked on a flat surface when taking measurements. The rear will flex before the front.
  3. Feb 1, 2016 at 10:05 AM
    tethsojh
    Quad Cities, IL
    I've parked it in several level locations. Checked my tire pressure, etc. It is the same everywhere I measure it.
  4. Feb 1, 2016 at 1:00 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Measure with a half tank of gas too, that makes a big difference.
  5. Feb 1, 2016 at 2:40 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    How do your leafs look? Any broken?
  6. Feb 1, 2016 at 2:42 PM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    thisssssssss
  7. Feb 1, 2016 at 3:43 PM
    tethsojh
    Quad Cities, IL
    Nothing appears to be broken. Also, i measured it with a full tank, and now a half of tank. Its still over an inch difference. :(
  8. Feb 1, 2016 at 3:47 PM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    Have a Z71, it leans, also. I just don't know.
  9. Feb 1, 2016 at 4:37 PM
    bigteninch
    bigteninch Active Member
    Scott
    Greenville SC
    15 TRD Off Road
    Does Toyota not have some sort of spec for "allowable" tolerance in ride height? Every vehicle that I have actually owned an official shop manual indicates ride height +/- and how and where to measure. I would think the Taco also has this. If one side is out of tolerance then they should fix it.
    I know the dealer SA response is that is normal but they are not technicians.
  10. Feb 1, 2016 at 4:39 PM
    Fitz235
    Rob
    New Hampshire
    He's got an '09. No warrantee.
  11. Feb 1, 2016 at 5:10 PM
    bigteninch
    Scott
    Greenville SC
    15 TRD Off Road
    I actually meant in general - with so many people discussing the "lean" plus the fact that some lean more than others, etc. There is typically a spec. Spec and allowable tolerance on ride height, on spring rates, etc. I mean dang how can a company like Toyota not recognize this and make the spring rates different for left vs right?? Seems like the left side rates need to be higher if there is more weight on the left - period.
  12. Feb 1, 2016 at 5:22 PM
    Fitz235
    Rob
    New Hampshire
    The lean that most people talk about is in the front. It's usually ~.5" lower on the driver's side. The springs actually are different from driver's to passenger. They are only off by the smallest margin, most people couldn't even visually notice it.
    The OP has something different going on.
  13. Feb 1, 2016 at 5:53 PM
    bigteninch
    Scott
    Greenville SC
    15 TRD Off Road
    Fair enough. We just got a '15 late this past calendar year and it leans over an inch to the left front and rear - all brand new. I would really like to find out the factory tolerance on this so I could get very specific with the dealer about the problem and a fix.
    I will post up measurements on a totally flat surface later this week when I get some time.
  14. Feb 1, 2016 at 6:14 PM
    addicus24
    Jeez RL, t
    Jeez, RL, that's a hell of a lot of pizza, huh? Thick crust and all, with anchovies!
  15. Feb 1, 2016 at 6:40 PM
    addicus24
    Jeez RL, I can't even post correctly!
    Alexely999 likes this.
