rear driveshaft, advice plz
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jofixer, Nov 9, 2011.
  1. Nov 9, 2011 at 2:22 PM
    jofixer
    jofixer [OP] Well-Known Member
    joe
    webberville, mich.
    SR5 sport 4x4
    06 dbl cab ted sport 4x4. 121 k miles. Rear driveshaft sounds like a seagull. Dealer wants 800 bucks. It runs out. I can feel the play when I push up on it. Ok start.....
  2. Nov 9, 2011 at 4:35 PM
    Overlander
    Overlander Well-Known Member
    One piece replacement sounds like the way to go.
  3. Nov 9, 2011 at 6:12 PM
    Blueanimal
    Blueanimal Well-Known Member
    New Orleans area, La
    06 Prerunner Sport
    K&N 77 series intake, Throttle boby spacer, Bilstien 5100, Firestone airbags, Brush Gaurd, Gooseneck hitch, Whelen lights and siren
    You sure it's not your u joints?
  4. Nov 9, 2011 at 6:14 PM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    What do you mean by it runs out? Were is the play middle, closer to the transfer, or closer to the rear diff?
  5. Nov 10, 2011 at 1:57 AM
    jofixer
    joe
    webberville, mich.
    SR5 sport 4x4
    Runs out means, if you were to put an indicator on it it would show a wobble. not concentric. I got under it, blocked up in neutral, and found no play in the front or rear u-joint. As I rotated either wheel, I could hear a screech that would come and go. When moving from a stop slowly it goes rip, rip, rip, till it quietes down at speed. Then it vibrates at 50 plus MPH. Anyway as I said, If you push up in the middle of the shaft, I can feel the inside front yoke move inside the rear yoke, not where it goes in by the rubber boot, but more towards the middle inside. I dont have the cakes to buy an expensive setup. Since I have access to redneck eng. I may have to resort to such means. comment on plz.
  6. Nov 10, 2011 at 5:38 AM
    SampleFool
    Ga
    Silver
    08 off-road
    Im going to see if there is any play in mine, cant say I have ever noticed any or not with any drive shaft.
  7. Nov 10, 2011 at 5:51 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I have a single piece DS with the same play in slip yoke. I recently greased it using a Teflon grease, but it only fixed the vibes and noise for about 100 miles or so. I have helper springs, but no lift, so I'm not sure that shims would help or hurt. Was looking into driveshaft spacers to push the yoke together a bit more, but I'm afraid of "bottoming out" yoke joint and destroying my pinion bearing, diff, or transmission. The helper springs raise the back end about half to a full inch, but the vibes and grinding were there before they were installed.
  8. Nov 10, 2011 at 7:19 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Replace your u-joints, all of them. A ball joint press rental from autozone will help get them out. Make sure you match mark the ends so you reinstall them in the EXACT orientation they came out, or you'll have a bad vibe.
    Greasing them might change the pitch of the noise, or make it go away(for a short time). This would be a good diagnostic tool to prove it is the u-joints. Odds are, if they are originial, they're bad. That noise indicates brinelling of the pins inside the u-joint due to no lube.
    DO NOT WAIT to install them. It won't take long for the u-joint to fail once brinelling starts.
  9. Nov 10, 2011 at 2:43 PM
    jofixer
    joe
    webberville, mich.
    SR5 sport 4x4
    OK. Just to let you know....I greased everything about three weeks ago. [tranny to pinion on differential] still made squeak. So I have to drive it another week. No days off till then. I will attempt to do the U-joints next weekend. Thanks for the logic. Will post up with results
  10. Nov 13, 2011 at 3:47 PM
    jofixer
    joe
    webberville, mich.
    SR5 sport 4x4
    per Skytower, I removed the driveshaft to begin changing all 3 u-joints. The rearmost one was siezed. Found the squeak. Derp on my part. It didn't occur to me that the u-joint could be toast and still have no play. Inside one of the caps was dust. The other 3 were fine. A big THANK YOU to SKYTOWER! This site rocks! Now all I have to do is figure out how to rep skytower.
  11. Nov 13, 2011 at 3:51 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Look under his name at the bottom of the post and there are three icons. The furthest left one is for repping. It is silver in color, to its right is the blue "quick pm" button and to its right is the red "report post" button
  12. Nov 13, 2011 at 3:51 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    click on the lil lower left icon under his name thingy
  13. Nov 14, 2011 at 10:21 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Just look at all the TW love here
  14. Nov 14, 2011 at 10:24 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Hopefully it didn't stress the ears where the u-joints ride. You didn't find any stress cracks or deformation, right?
  15. Nov 14, 2011 at 10:45 AM
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    Also, did this help cure your vibrations at all?
    I have the typical starting and ~50mph drive line vibration. 78k on the truck with original ujoints. I grease them. Have shimmed the axle to be on 0 with the transfercase, made it worse. So confused.
  16. Nov 14, 2011 at 10:57 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    The overall angles from trans to diff should be split through the whole driveline. Two part driveshaft will require shims at the carrier bearing. Measure all parts of the driveshaft with an angle finder to check.
  17. Nov 14, 2011 at 11:30 AM
    06RadiantRed
    CA-Bay Area
    So your saying if the front shaft angle is 5 degrees off the trans, the back half should be 10 degrees off essentially?
  18. Nov 18, 2011 at 2:54 PM
    jofixer
    joe
    webberville, mich.
    SR5 sport 4x4
    sorry for the late reply guys... no vibrations. also no scrambled yoke. also no shims under the carrier bearing. OK for those of you that are familiar with yer geometry, my .02 of course. the amount of angle that you are going to change both driveshafts {with shims} is going to be very small. some would say what if I shim it 2 inches? OK, that is a big change. for the sake of argument you are correct that shims will change the angle. However, u-joints being what they are, they are not rotating at a constant speed, and the amount of angle dangle you change them is being like a squarehead, straightening all the pictures in a room. Oh snap, I'm a squarehead. Enlighten me if I am TOTALLY mistaken.....
