Rear Driveshaft Measurement
Discussion in '1st Gen. Tacomas (1995-2004)' started by bellassaiw10, Jan 25, 2012.
  1. Jan 25, 2012 at 11:15 AM
    bellassaiw10
    bellassaiw10 [OP] Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    In the midst of doing the Prerunner to 4x4 swap and I'm gonna be trying out the transmission this weekend but the problem is I don't know how long my new driveshaft needs to be :confused:. Do I need to replace the entire driveshaft or just on piece of it ?? Haven't been able to find a solid answer on this if so whats the total length of the Rear driveshaft for you 4x4 thanks
  2. Jan 26, 2012 at 10:45 AM
    bellassaiw10
    Currituck NC
  3. Jan 26, 2012 at 3:26 PM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    The rear driveshaft on a 4x4 is 2 piece. You should have a spot on the frame to mount the center support bearing, that is about the halfway point. You best bet is to try and find a used one at a local scrapyard as Toyota charges an arm, a leg and your firstborn for one.
  4. Jan 26, 2012 at 3:31 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    i just measured mine and approximetly 68 inches total length for both shafts. give or take 1/16 of a inch.
  5. Jan 26, 2012 at 3:34 PM
    907taco
    Bobby
    Alaska
    just read your post and the rear shaft is 41 1/8 end to end. (approx)
  6. Jan 26, 2012 at 3:36 PM
    907taco
    Bobby
    Alaska
    but i am second gen. so i probably didnt' help! I tried.
  7. Jan 26, 2012 at 5:18 PM
    bellassaiw10
    Currituck NC
    got it thanks guys ha, behind the center bearing is the same length on all my front is 39.5 and 4x4 is 27.5 hopefully getting one in the morning and gonna go ahead and put the tranny in and wait for the front end
  8. Jan 26, 2012 at 5:51 PM
    livnlrn
    livnlrn Well-Known Member
    Rick
    Elkton, Virginia
    2009 TRD double cab
    Dont know what ur set-up is, but u can always get a shaft made & do away with the carrier bearing.
  9. Jan 26, 2012 at 6:08 PM
    bellassaiw10
    Currituck NC
    Problem is, is that this is my daily driver so I needed the replacement but I got it straight
