Rear Drum Brake Noise?
Discussion in '1st Gen. Tacomas (1995-2004)' started by wurthit4660, Oct 8, 2011.
  1. Oct 8, 2011 at 5:45 PM
    wurthit4660
    wurthit4660 [OP] Well-Known Member
    Hollywood
    St.Louis, MO
    02 Taco Prerunner ExtCab SR5 TRD
    K&N Cold Air Intake Flow Master Muffler 3" Suspension lift
    here's whats going on, vehicle in park, not running. i depress the brake pedal and there is a loud ass squeak that comes from the rear drum, this happens everytime i depress and release the brake pedal. i crawled under the truck to see if i could pin point where exactly it's coming from but no luck, and from what i could tell it appeared to be both sides but not 100% on that..
    when im driving and apply the brakes it will happen but its not as noticable because of other noises. No brake squeaking while brakes are being applied for stopping like you would normally get from the front brake pads when they are bad/run down. I am not familiar with drum brakes and was wondering if this indicates the drum shoes are bad or something else going on with the brake system?
    Im not having any trouble stopping or having to really depress the brake pedal in order to stop, brakes seem fine its just that damn squeak...
    Anyone?
  2. Oct 8, 2011 at 5:52 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    The backing plates are dry. each shoe rides on 3 points. that's where the squeak is coming from. Need to remove drums and lube the contact patches with a little brake grease. Won't hurt anything.
  3. Oct 8, 2011 at 6:13 PM
    wurthit4660
    Hollywood
    St.Louis, MO
    sweet thought it might be something easy, well was hoping..haha thanks ;)
  4. Oct 8, 2011 at 6:22 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    It is pretty easy if the drums are not seized or a big rust ridge.
    PITA if they are.
  5. Oct 8, 2011 at 6:56 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    How many miles on the truck? Mine's an '02 with 114K and still on original rear brakes. I inspected them a couple of weeks ago (really easy as Tacoma Mike mentioned), mine still have 50% of the shoe surface left.
    I would say, it you are not having any issues stopping or pulling to one side, you are probably OK if you can tolerate the squeak.
  6. Oct 8, 2011 at 8:08 PM
    wurthit4660
    Hollywood
    St.Louis, MO
    lol mine has just turned 114xxx last week... well since it seems to be a somewhat easy fix if the drum face comes off, it's prob worth a try b/c i really dont like the loud squeak it's bad...
  7. Oct 8, 2011 at 8:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :eek: Sounds about right.
    Yeah, give it a try. Loosen (not remove yet) the lug nuts on both rears, put the axle on jack stands, then remove the wheels. The drums may slide off at that point. If not, tap/pound on them with a hammer to break'em loose. That is all it took on mine.
    I would suggest having a couple of aerosol brake clean cans handy to spray it down and clean everything up. You can then do a proper inspection. Good luck Man!
  8. Nov 6, 2011 at 2:16 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    does this require the removal of the brake pads themselves? i too am having this problem and i am wondering how i go about greasing the contact points
