Rear drum brake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pcm888usa, Apr 30, 2016.
  1. Apr 30, 2016 at 2:56 PM
    pcm888usa
    pcm888usa [OP] Member
    CA
    06 PreRunner SR5 V6
    TRD Exhaust, Clarion NX500 Nav/Radio, ERB Slotted front disc brake and pads
    hello guys,
    How do I know when to service the rear drum brakes?
    Do I go by miles driven?
    Thanks.
  2. Apr 30, 2016 at 3:04 PM
    Clearwater Bill
    Billy
    Largo Florida
    That's a good start.
    There is a shoe thickness spec that you can measure if you wish, as well as examining wear in the drum itself. But the service life can be maximized and many problems avoided just with periodic basics.
    Clean out the dirt/dust and wash down the backing plate/components.
    Lube friction points that specify lube.
    Make sure no springs are broken
    Make sure the wheel cylinder is dry, not leaking brake fluid
    Make sure the adjuster turns freely
    Lubricate ebrake components
    Reinstall the drum and manually adjust the shoes per spec
    Assuming a street driven truck, every 10k/second tire rotation should be adequate for this attention. Of course do it when you do your two year brake fluid flush and fill.
    If the truck is heavily off roaded, particularly in wet/mud, more frequent inspections would be reasonable.
    Generally the rear shoes should last about 2x the front pads.
    SAR Taco and Jimmyh like this.
  3. Apr 30, 2016 at 5:47 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What he said. ^^^^^^^^^^^^^
  4. Apr 30, 2016 at 7:06 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Generally, you go by material left on the pads/shoes. As a general figure for all brake systems, minimum material is 1/16th or 1.5mm on pads and shoes from nearest metal point or rivet. However, 2mm is a better figure to avoid going metal to metal. In addition to above, shoe/pad wear should be even.
    http://www.dummies.com/how-to/content/how-to-check-drum-brakes.html
