Rear Drum Vs Disc
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JStiner, Oct 11, 2016.
  1. Oct 11, 2016 at 11:22 AM
    JStiner
    JStiner [OP] Well-Known Member
    11 MGM 4x4 4.0 double cab
    KO2s (32s) with 2inch level
    Who's ready for a stupid question today?
    I've currently got Front Disc and rear Drum; why rear Drum and not all 4 disc?
    what is the advantage to having rear drum?
    it is work converting the rear to Disc?
  2. Oct 11, 2016 at 11:28 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
  3. Oct 11, 2016 at 11:31 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C’d DCLB TRD SPORT
    I don't think it's worth converting to discs for a small optimal change in performance and aesthetics.
    JStiner[OP] likes this.
  4. Oct 11, 2016 at 11:32 AM
    JStiner
    interesting... thanks for the link
    eccracer104[QUOTED] likes this.
  5. Oct 11, 2016 at 11:33 AM
    JStiner
    from the link @eccracer104 posted, it looking like paint them black and call it a day...
    they're not work messing with .
    eccracer104 and mjp2 like this.
  6. Oct 11, 2016 at 11:43 AM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    the Colorado has rear disks and it has a 60-0 of 131 ft
    While the tacoma has 60-0 of 125ft on the offroad and 132ft on the rest of the trucks
  7. Oct 11, 2016 at 11:48 AM
    TastyTaco
    TastyTaco Well-Known Member
    Nick
    Vancouver, WA
    2003 Taco 3.4 DC TRD
    3" Lift, BFG K02 285/70/17, Pro Comp 45 Series 17x9 -6, ACME D2S Retrofit
    Why mess with what works. The trucks will sell themselves no matter what Toyota does lol. I like the look of discs personally.
  8. Oct 11, 2016 at 11:50 AM
    TegoTaco
    Ontario, Canada
    I like the looks of discs too, a nice smoothly sanded down drum with fresh paint looks ALMOST just as good.
  9. Oct 11, 2016 at 11:50 AM
    JStiner
    I'm just lazy and don't like working on drums
    M192 likes this.
  10. Oct 11, 2016 at 11:51 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    IF discs were better, then why do cargo semi-trucks/ trailers use drums?
    If the Chevy Colorado uses discs in back, that is just another GREAT reason for Toyota not to!!! LOL
  11. Oct 11, 2016 at 11:52 AM
    TacoJova
    Central Oregon
    Drums but with air and some actually do have hydraulic disc brakes
  12. Oct 11, 2016 at 11:54 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Rear drums on these trucks work fine, but as much as a new Tacoma costs, there is no excuse in my opinion for them to come with drums. To answer the OP's question, no, it's not worth it to convert to rear disc brakes. JMO.
    BDL5589 and JStiner[OP] like this.
  13. Oct 11, 2016 at 11:56 AM
    Aw9d
    Aw9d That one guy
    I want rear discs for 2 reasons.
    1. They look awesome.
    2. I hate working on drums.
  14. Oct 12, 2016 at 12:25 PM
    tgear.shead
    tgear.shead Well-Known Member
    I had an S10 (same thing, but older name) with 4 disk brakes. Don't know how many times I had to redo the back brakes because they ROTTED and ROTTED and ROTTED. Something about having all that salt crap spraying all over it every winter and not nearly enough work from them to keep them clean.
    Snowman likes this.
  15. Oct 12, 2016 at 1:21 PM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    On the contrary, it takes a higher psi to compress drums over disks, going to disks, to do it properly, you would need a proportioning valve that will re distribute the brake fluid psi properly to each wheel, or your rear end will lock up real easy on a hard brake (with disk in place of drums). Drums have an advantage over disks for vehicles that have a heavy load, you get the forward momentum that helps engage them.
    You can get a rear end setup that will function just as good as the drums, but I do not believe our trucks have the ability to change the proportioning valve, in the TRD OR I believe it is build into the master cylinder. There is a conversion out there that basically pulls the rear end off a Tundra, but not sure how they re proportioned the fluid pressure. But the tundra is also in a completely different weight class than the tacomas. I met a guy who did it and he cannot get the brakes to function properly, but his truck was purely a desert prerunner, not street driven.
  16. Oct 12, 2016 at 2:29 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Thank you for the correction! I knew there was something to do with not having the correct pressure, but it has been a while since I read on the subject. Thank you for providing the correct information :thumbsup:
    WhiteNemesis[QUOTED] likes this.
  17. Oct 14, 2016 at 10:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There is a 4Runner conversion. I am still amassing the parts. Sold by www.tundraracing.com. Just have one caliper left to purchase. There are also adjustable proportioning valves availableto purchase, if there is a problem.
    Another point: People who off-road through silty waters, muddy waters, can have their drums' shoes wear out incredibly quickly. Happened to me, and other members.
    The foreign sediments stay in the drums and continually wear out the pad material, much faster than without. Disk, it is much harder for that sediment to stay.
  18. Oct 14, 2016 at 12:47 PM
    TastyTaco
    Nick
    Vancouver, WA
  19. Oct 14, 2016 at 1:22 PM
    JStiner
    So disk brakes are the sexy 20 year old you keep for the weekend and Drums are the reliable wife you keep for the long haul.
    Got it.
    Nedrolls, smmarine and David K like this.
  20. Oct 14, 2016 at 1:38 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I'd still rather have discs. How come 4Runners, Tundras, Wranglers, Range Rovers and just about every other truck on the road now have rear disc brakes? For 40k and up I WANT REAR DISC BRAKES!!! Sorry about the rant. I'm cranky today.
    Tex-Tac and BDL5589 like this.
