Rear drums shutter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glamis, Jun 27, 2011.
  1. Jun 27, 2011 at 12:12 PM
    Glamis
    Glamis [OP] date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    I have a 2008 4Door LB TRD sport. Wile I'm back up my truck in the morning or after I back out and start to drive away. I get a shutter from the rear brakes. Like there stuck or something. only will happen one time then it does not do it all day. I clean out my drums and adjust them as need but still seams to happen. Does any one have thing going on? So over drum brakes!!
  2. Jun 27, 2011 at 12:16 PM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Are you sure it's the brakes and not the driveline? Sounds more like a driveline shudder to me...
  3. Jun 27, 2011 at 1:29 PM
    Glamis
    almost 100% it is the brakes. When I'm backing out of my drive way I need no gas I'm ridding the brakes down my drive way. The drums will shutter then or just after i go forward.
    My brakes work well and seem to be wearing normally.
  4. Sep 29, 2014 at 9:59 AM
    AL W
    AL W Well-Known Member
    Panama City, FL
    2013 PreRunner
    Truxdeo Lo Pro QT Soft Roll-Up Tonneau Cover Color: Silver
    I would try replacing all of the springs. It's a cheap fix (about $20). After that I would suspect contaminated brake linings or the surface of the drum has glazed over.
    Regards,
    AL
  5. Sep 29, 2014 at 2:06 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    Black Taco '12 4x4
    Delay wiper mod. "Access" Tonneau cover. BedMat.
    I seen drum that wear at an angle. The ID of the open end and bottom are different size. Typically the brakes wear to match the drum and it evens out - but reverse may cause the brakes to shift. Another reason to be sure and check and turn the drums when you replace the shoes. On the vehicle I saw, the brakes were new and the drums not turned - so it caused a clicking sound as the brakes were applied and the brake shoe rode the taper in the drum.
