Rear drums, swap w/ 4runner?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Booster, Jan 24, 2017.
  1. Jan 24, 2017 at 1:53 PM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    what are the symptoms you are noticing on the "overheated" brakes? have you checked operating temps of all corners with an IR thermometer gun? having driven and worked on both i dont see the big disadvantage everyone complains of with drums. if they werent up to the job they would not be the go to brake system for the biggest, heaviest (often most expensive) vehicles on our roads
  2. Jan 24, 2017 at 2:27 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    I know that for the 2nd generation Tacoma TRD offered upgraded front brake pads. Maybe look into upgrading your front brakes.
  3. Jan 24, 2017 at 2:31 PM
    brich999
    Bryan
    all tore up already
    but WHY? are thge rear drums really getting so hot they are gassing and causing fade? i doubt it. id be concerned why the rears are not working before i considered higher performance pads to compensate
  4. Jan 24, 2017 at 2:33 PM
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    Does the 2016 / 2017 Tacoma still have a load sensing valve for the rear braking system? If it does maybe that wasn't adjusted properly? Brakes are not a simple on off affair any more.
  5. Jan 24, 2017 at 2:37 PM
    Herniator
    Edmonton
    The front brakes do most of the braking. Especially downhill. He wants rear disc brakes thinking that they will provide more rear braking. If he gets rear disc brakes the front brakes will still be doing the vast majority of the braking. And he also claimed that the front brakes are the ones overheating.
  6. Jan 24, 2017 at 3:30 PM
    Storman
    Storman Fukitol abuser
    South Western PA
    2017 SR AC 4x4 AT AC UP ->LONG BED<-
    Whole bunch of shit! $$$
    Drum brakes are what made me buy!
  7. Jan 24, 2017 at 3:43 PM
    Booster
    Booster [OP] Well-Known Member
    1999 TRD 4Runner
    Bilstien Shocks 2.5 Inch Lift TRD supercharger TRD Exhaust Transmission Cooler K&N Intake Aftermarket headers Performance Parts Progressive Springs
    So here's the deal, i'll explain instead of quoting.
    I go down a steep hill, with engine braking, and still need to ride my brakes for most of the part. I keep letting off to air them, but it just isn't long enough to let them cool. They start mushing out at the bottom of the hill.
    I've done many replacements to the rear drums as they start making noise and shuttering. I also, unfortunately, needed to replace the rotors 2 times (the heat warps them. Similar to the drum self destructing with heat) I ended up settling for crossdrilled//slotted rotors. The thing is, the drums take way to long to cool down. I have even tried running/ducting air to blow straight on the drums. didnt help at all.
    Not saying drums are bad. I'd be perfectly content if i didn't have to commute over a gnarly hill. It's just that drums possibly aren't the best component for my current situation.
  8. Jan 24, 2017 at 3:47 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    considering all big rigs use them...clearly they have some decent stopping power.
    the heating is the only issue I've ever seen with them and that wasn't even personally.
    Never had a problem with them on previous vehciles
    0210[QUOTED] likes this.
  9. Jan 24, 2017 at 3:50 PM
    Joe23
    still convinced its your driving style.
    I'm sure plenty of people drive those same roads with drums and have no problems
    Have you considered checking your brakes for adjustment?
    Perhaps the rears just aren't working as they should be and have to adjusted?
    I've driven in areas with significant hills and never had an issue.
  10. Jan 24, 2017 at 3:55 PM
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    What I would start with I'd the tundra brakes in the front, if that still doesn't fix it there is a guy over in t4r who swapped his drums for fj60 rotors, and mini truck calipers. That's the only rear conversion I have seen
    Edit: saw this was red gen not 1st, my bad
    Joe23 likes this.
  11. Jan 24, 2017 at 3:57 PM
    Booster
    1999 TRD 4Runner
    I've personally adjusted the tension on the cable running to the rear drums. Not too sure about people running drums here. Most cars are pretty new sedans. Trucks aren't a common need, except i need one to get up a rough, muddy road up to my house. Got to love private roads when the neighbors don't want to split the cost to pave the road!
    Joe23[QUOTED] likes this.
  12. Jan 24, 2017 at 3:58 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Okay. This is a long shot. It kind of sounds like you might have compromised brake fluid. The symptoms you are saying are similar to moisture in the brake fluid. It's possible that it's the extreme heat of the brake fluid near the calibers are boiling the moisture to a gas (steam) which is compressible (mushy). Clean and pure brake fluid without moisture will remain a liquid and isn't compressible. It's an easy and cheap fix to buy and flush out all the brake fluid at each wheel and in the master cylinder. (My opinion is worth the price paid!)
  13. Jan 24, 2017 at 3:59 PM
    Joe23
    I'd say take the above post idea first.
    Get better front brakes.
    in terms of physics, changing the rears won't really do much for the fronts. Sure it will help but the fronts still take most of the braking and sounds like you need more front stopping power.
  14. Jan 24, 2017 at 4:01 PM
    Booster
    1999 TRD 4Runner
    Holy moly! You can get the tundra breaks on the front? Is it easy? That extra surface area would seriously help my braking!
  15. Jan 24, 2017 at 4:01 PM
    #35
    Expl_eng
    Expl_eng Well-Known Member
    Anthony
    NC
    Black 2016 4x4 DCLB Sport
    Black Pro clone/Kicker Audio/wet okole covers
  16. Jan 24, 2017 at 4:02 PM
    #36
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Some People are too lazy to learn how to swap drum shoes.
    gpb and Joe23 like this.
  17. Jan 24, 2017 at 4:07 PM
    #37
    Joe23
    personally don't know as the factory brakes are fine to me so haven't looked into it.
    Just saying it was suggested and if it is an easy swap its probably more effective than changing the rear.
  18. Jan 24, 2017 at 4:12 PM
    #38
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    People have already explained the drum vs disc thing so I'll save my breath but I will post this if you're die hard on doing a rear disc swap:
    DO NOT SWAP TO REAR DISCS WITHOUT ALSO ADDRESSING THE BIAS PROPORTIONING VALVE
    This is often neglected and will lead to you having less (possibly dangerously less) braking power!
    The basic rundown is this: drums require less line PSI to get a certain amount of braking torque out of them. Because of this, your stock proportioning valve is going to apply less pressure to your rear brakes when you press the pedal. It's just simple physics to keep them from locking up versus your front wheels. And so, if you just swap in calipers onto the same lines, you will be attempting to actuate calipers with drum-oriented line pressure. It's simply not going to work as well.
    Joe23 likes this.
  19. Jan 24, 2017 at 4:13 PM
    #39
    Nitori
    Maricopa AZ
    2021 T4R SR5
    no no no no stop stop stop this
    3rd gens already have Tundra front rotors and calipers talked about aaaaaaaa this keeps popping up
    :rofl: (not trying to single anyone out it just keeps getting mentioned, and is misinfo)
    GPsevinSixx and Joe23[QUOTED] like this.
  20. Jan 24, 2017 at 4:27 PM
    #40
    DIRT TACO 16
    DIRT TACO 16 Well-Known Member
    Greg
    2016 TRD OFF ROAD 4X4
    AIR CONDITIONING DRAIN EXTENSION
    Have you tried to get custom rear shoes made. I have used a place near me that makes racing brake pads/shoes. I have seen pads and shoes that make abs skid.
