Rear drums
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Koogle99, Dec 17, 2023.
  1. Dec 17, 2023 at 11:38 AM
    Koogle99
    Koogle99 [OP] Member
    2020 Tacoma
    I have a 2020 Tacoma that I had to have the rear drums replaced in July of 2021. I recently had to have them replaced yet again. A week into the new drums the truck is shuddering like crazy again!!! Any thoughts? It’s out of pocket now so I don’t want to put a third set of drums on if there’s a known issue causing this. Anyone? Thanks!
  2. Dec 17, 2023 at 11:41 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i think the axle shaft or flange was bent in my truck. spent thousands and months trying to fix it before selling it. no one could figure out the issue.
    Junkhead likes this.
  3. Dec 17, 2023 at 11:44 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    something else is wrong, drums should go 100k, and often times many many more.
    Sounds like improper diagnoses and/or repair.
    YF_Ryan and Junkhead like this.
  4. Dec 17, 2023 at 11:47 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    That’s a shame. How does this happen? Can’t believe it was a manufacturing issue. Did you buy the truck new? Maybe it was hit in the rear?
  5. Dec 17, 2023 at 12:28 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I’m at 55k miles and still haven’t even opened them up.
    :facepalm:
    Brakes are very smooth though! :)
    oconnor and Tocamo like this.
  6. Dec 17, 2023 at 2:29 PM
    RebleAZ
    RebleAZ Well-Known Member
    Troy
    AZ
    2020 Cement TRD Off Road
    Fox Performance Elite, RRW -25 RR7H, 295/70/17 Yokohama Geo MT. Alcan Leafs. Much more...
    This doesn’t sound right at all. Usually the front discs get warped and cause a brake shudder but not so much drums. And you shouldn’t go through a new set in a week. Not sure what you have going on but take it somewhere else reputable.
    YF_Ryan and Chew like this.
  7. Dec 17, 2023 at 2:38 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Is it doing it on deceleration between 30-10mph? If so there is a tsb out to replace the rear leaf springs and add a steering damper behind the air bag.
    Tacoma1818 likes this.
  8. Dec 17, 2023 at 3:21 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Check into this a little deeper . There is something not right . Go to a different dealer or a good mechanic . This is not normal . The drum brakes are very reliable, don’t listen to some of the complaints here about them . The only issue I’ve ever had with drum brakes is one time I washed the truck and the temp dropped like 50 degrees in a few hours , and by mistake I put the emergency brake on . The next morning when I released the brake the wheels were frozen , but I was able to free it up pretty quickly .
    Chew likes this.
  9. Dec 18, 2023 at 4:10 AM
    Koogle99
    2020 Tacoma
    Thanks for the feedback. Front brakes have been checked. Truck shudders when braking. Especially if coming down a hill. There is a bit of a vibration coming from the rear of the truck while driving this time.
  10. Dec 18, 2023 at 12:17 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    if you can duplicate the shudder, maybe slide the transmission in to neutral (if it's safe) and see if you can isolate?
    Koogle99[OP] likes this.
  11. Dec 18, 2023 at 12:21 PM
    Koogle99
    2020 Tacoma
    I’ll try that Chewy. I especially feel it going downhill.
    Chew likes this.
  12. Dec 18, 2023 at 4:11 PM
    Tacoma1818
    Tacoma1818 Well-Known Member
    any link to this?
    Edit, found it. Says auto trans… boo
    https://static.nhtsa.gov/odi/tsbs/2020/MC-10187246-9999.pdf
  13. Dec 18, 2023 at 4:55 PM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    Remove the rear wheels (safely) put on jackstands.
    put suitable device (a dial indicator would be best) at bottom of the axle flange. With front wheels chocked put in trans in "N" Have someone rotate the other wheel while you look for any runout of the axle flange. If no runout is noted then you have eliminated one source.
    Put trans back into park or gear
    Koogle99[QUOTED][OP] likes this.
