Rear e-locker
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dj318, Aug 3, 2014.
  1. Aug 3, 2014 at 10:22 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    This is what i was thinking^
  2. Aug 3, 2014 at 10:33 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    It's like 10 minutes to take an axle off.... Remove drive shaft, remove u bolts, remove brake lines, pull axle out.
  3. Aug 3, 2014 at 10:36 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    LMAO... OK :rolleyes:
    Brakes lines in the NE salt belt can take a hour to remove alone and I'm not talking about re-flaring them if thats needed.
  4. Aug 3, 2014 at 10:42 AM
    AR15xAR10
    He has a new frame, we are not as blessed as him :rolleyes:
    :D i'm just teasin'
  5. Aug 3, 2014 at 10:45 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    North Carolina is hardly a rust belt state.
  6. Aug 3, 2014 at 10:47 AM
    XXXX
    sKiP
    05 Prius
    First day I have you off ignore and you're going right back on... you have no clue
  7. Aug 3, 2014 at 10:48 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Why? You going to be street racing? ;)
    ... and he would keep a much stronger unit all the way around. The cast iron girdle or whatever we call it ensures that there is very limited change in backlash under load. I would keep that 8.4 and get an ARB.
  8. Aug 3, 2014 at 10:51 AM
    XXXX
    sKiP
    05 Prius
    nah...old one is rusted and I don't trust anyone here resurfacing it (I was told I should resurface it but notsure). I still have some researching to do because I'm clueless on some of the tech.
  9. Aug 3, 2014 at 10:58 AM
    AR15xAR10
    :yes:
  10. Aug 3, 2014 at 11:19 AM
    Dj318
    Dj318 [OP] Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    But the arb runs about 4 times what I'll be paying
  11. Aug 3, 2014 at 11:36 AM
    amain
    amain Well-Known Member
    Brian
    Anacortes, Washington USA
    07 SC TRD FJ - The Black Lemon
    Fender Cracks
    I would think twice about that swap. I have a 2007 FJ and I had blown 3 sets of R&P gears out of the 8" with e-locker. The last time it happened I bought a 8.2" axle assembly without locker and installed the ARB. Much stronger than that 8". In the long run you won't be saving any money for a locker if you have to replace the gears. I'm not sure about the 8.4" but the only difference on my swap was the sway bar mounts.
  12. Aug 3, 2014 at 11:51 AM
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    Well does anyone know of any where to pick up a arb for less than a grand?
  13. Aug 3, 2014 at 12:13 PM
    HBMurphy
    Paul
    So California Coast
    None
    I think I might agree. ;)
  14. Aug 3, 2014 at 12:14 PM
    HBMurphy
    Paul
    So California Coast
    None
    I bought nib for something like 900. Just don't get a 3 pc.
  15. Aug 3, 2014 at 1:41 PM
    #35
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Swap the axles its way cheaper and eaiser than an arb. Don't listen to the webwheelers you won't break the 8" wheeling if you are under 35s. I've been wheeling since 2005 with my trd and I've had a crawler since 2008 and zero problems. The elockers reliable and it flat works. I have seen more people dicking around with arb problems on the trail than elockers having problems.
  16. Aug 3, 2014 at 1:50 PM
    #36
    XXXX
    sKiP
    05 Prius
    I concur with your conclusion :D
    everyone I know who blew one was on smaller tires than 35's
    also hows that leaky actuator ? besides the gears being thinner Ive seen them fail due to water immersion.... and not on the web :cool:
  17. Aug 3, 2014 at 1:50 PM
    #37
    TrdSurgie
    TrdSurgie revised
    Oahu
    Lol. ^^
    I agree swapping axles is a pain when dealing with someone else's truck and your own truck. I would just do the arb route too unless I was picking up a elocker rear from the yard.
  18. Aug 3, 2014 at 1:53 PM
    #38
    HBMurphy
    Paul
    So California Coast
    None
    ^^^^ Pride of ownership there. Its a good thing you can provide your expert advice to squelch the inexperienced web wheelers. It was certainly an anomaly that amin, myself and many others have 'blown' through 3 r&ps each. As a matter of fact, Toyota changed its elocker design so that they could limit the number of trucks that would have such an awesome rear end.
  19. Aug 3, 2014 at 2:21 PM
    #39
    XXXX
    sKiP
    05 Prius
    :laugh:
    Exactly!
    If the 8" rear was that good there wouldn't be dedicated threads to them blowing up on every major forum a year after the 2nd gens were produced. 11 pages of failures and 99% of them on smaller than 35" tires Gotta go...off to web wheel my truck some more :mudding:
  20. Aug 3, 2014 at 2:22 PM
    #40
    slander
    Hickory, NC
    That's a problem the 1st gens don't seem to have and one of the many reasons that the fjc and the 2nd tacos are steaming turds. Its pride of ownership because it flat works, and has zero problems with 200:1 running though it.
    Xxx what leaky actuator? I have done zero maintenance on this thing, no problems locks evreytime.
