Rear end clunk in cold weather.
Discussion in '1st Gen. Tacomas (1995-2004)' started by JCH, Jan 28, 2014.
  1. Jun 12, 2014 at 5:51 AM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Mine happens more in the cold. However, it has happened when its warm out side. I've even noticed when its raining (cooling off) it will happen more.
  2. Jun 26, 2014 at 12:16 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    I did some more checking and found my "knock".
    During hard turns to the right, the slight body roll (due to old/worn body mounts) is causing the pinch weld to hit my driver side slider. I have a 1/16" gap between the pinch weld and slider but they've definitely come in contact.
  3. Jun 26, 2014 at 12:21 PM
    kigmob
    James
    New Orleans
    Glad you found yours. It rained today and mine started doing it again. Once it stopped and dried up/warmed up, it stopped.
  4. Jun 26, 2014 at 12:23 PM
    dispatch55126
    MN
    2004 Xtracab SR5
    It's got to be a body mount issue everyone's having. I'm too cheap/doesn't bother me enough to replace the mounts with urethane.
  5. Jun 26, 2014 at 12:28 PM
    kigmob
    James
    New Orleans
    That's what I'm thinking mine is. And if that's the case then I'm not too worried. I'll have to check it out tomorrow.
  6. Dec 2, 2014 at 9:15 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Any update on this? With the cold mine has come back and I feel like it's getting worse. I'm still thinking body mounts but as far as I can tell they look ok. But I don't know how to tell if they're bad or not.
  7. Dec 2, 2014 at 10:10 PM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    Got the same problem happens mostly when its wet
  8. Dec 2, 2014 at 10:53 PM
    JCH
    JCH [OP] Well-Known Member
    Justin
    Colorado
    2021 TRD Off-road
    Just started to have the clunk coming back with the cold. Got it to happen just for a second just shaking the bed back and forth, but not long enough to be able to have somebody get underneath and check it out. Makes is super hard to chase down when it only happens when moving. I still think it has to be something directly connected to the frame just the way you can feel the clunk in your feet.
  9. Dec 6, 2014 at 12:06 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    I more hear mine than feel it
  10. Jan 12, 2015 at 7:21 PM
    Hillclimber
    Hillclimber Well-Known Member
    Justin
    NW Iowa
    2012 Baja
    I have this clunking also, It started when the weather got cold. I describe it as sounding like a worn out shock with the rubber bushing missing. If I stand on the receiver hitch and lightly bounce I can hear it very loudly but still can't pinpoint where it's coming from. It sounds to me like it's on the right rear but I don't know. Yesterday I was riding in the passenger seat which I rarely do and I could really feel it through the floorboard. It seemed like it was also coming from the front end sitting there. I hope it's just a cold weather issue, I sure couldn't find anything loose.
    Wrong Generation but same problem.
  11. Jan 13, 2015 at 11:50 PM
    kigmob
    James
    New Orleans
    My clunk is still there. Seems to really be the worst when it's wet. I wish I knew what the hell was clunking. Only happens when the truck flexes/twists around curves or up small curbs at low speeds.
  12. Mar 25, 2015 at 10:20 PM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    I've been chasing a clunk in my truck... I find one... Think it's solved...then I hear it again. So far I had a bed bolt loose... Could hear/see the bed creak and move as I bounced on the bumper. I greased my u and slip joints. Torqued u bolts. Now I think it may be my right rear fox shock shaft because there is a tiny bit of play when I shake the shock around. I continue to chase the elusive clunk....
  13. Mar 26, 2015 at 7:29 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Glad i found this thread. My truck does this everytime while pulling up in my driveway. All suspension parts are new and pan mounts are new. No spare, new straps on the tank, new u bolts, new u joints. I had one tinny bang every now and then but that turned out to be the heatshield mounted on bottom of bed. Seeing all others with same problem puts my worry at ease
  14. Nov 3, 2015 at 7:56 PM
    kigmob
    James
    New Orleans
    Bump. Anyone with similar symptoms got any suggestions?
  15. Nov 3, 2015 at 8:24 PM
    #35
    Hillclimber
    Justin
    NW Iowa
    2012 Baja
    Possibly but it might be too simple. I've found that the cheap thin plastic rear inner fenders slap up against the underside of the box because they are not held up tightly enough by the plastic things they use. I'm either going to plastic rivet them in tight or put a healthy dab of silicon on the topside of the inner fenders and reinstall them to give them a little cushion zone. This should not be something that would only be cold weather related but even though mine are loose and I know they slap, I still don't really hear it when it's not cold out. It's worth a shot as I can't find anything else.
  16. Nov 3, 2015 at 9:42 PM
    #36
    kigmob
    James
    New Orleans
    Hmm I never thought of this. When mine clunks though it definitely sounds like metal. And I can sometimes feel it in the floor board. I am wondering if maybe its some body panel underneath that flexes and pops? It happens mainly when the body flexes (going slowly up a bump like a curb onto a driveway, uneven smooth surfaces, body roll from turning, etc..)
  17. Feb 7, 2016 at 10:28 AM
    #37
    The_Trail_Yota
    The_Trail_Yota Well-Known Member
    Colorado
    2021 TRD Offroad
    Bells & Whistles
    Bump...anybody find anything out on this? Mine is doing it as well.
  18. Feb 7, 2016 at 7:03 PM
    #38
    MoreMonkey
    MoreMonkey Well-Known Member
    Maine
    red, stock, TRD
    Bilstein 5100
    I've got the clunk too. My Tacoma is mostly stock...just Bilsteins front and rear. I can tell you it's not the steering rack bushings or the body mounts because I replaced them with Energy Suspension and it made no difference. Lately I'm thinking it's the UCABs or LCABs or rear springs. But I'll grease the driveshaft first and see if that helps because that is so much easier.
  19. Feb 24, 2016 at 9:15 PM
    #39
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
