Rear end clunking
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacobuenos, Mar 9, 2023.
  1. Mar 9, 2023 at 2:27 PM
    tacobuenos
    tacobuenos [OP] Member
    lonnie
    95 tacoma
    95 tacoma rear end clunking. I hear it more when I let off the gas around 30 MPH. There was so much play in the axle and the diff was moving when the leaf would compress so I bolted the leafs together and I hope that stabilized it. But, I think it wasted the diff prior. There's so much play between the wheels and the drive shaft and I had the drive shaft balanced and the ujoint replaced. I had a misfire and the truck was surging which I think made whatever worse but I'm pretty sure it's the rear diff.
  2. Mar 9, 2023 at 4:08 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
  3. Mar 10, 2023 at 5:09 AM
    tacobuenos
    lonnie
    95 tacoma
    I thought so too so I ubolted the leafs together to stiffen them up but the damage is done as I still hear it clunking at low speeds and when I'm either not throttling or barely throttling.
  4. Mar 10, 2023 at 5:11 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    So what do mean by clunking? Your post doesn’t really give us much to go off of.
    how are the shocks and their bushings?
  5. Mar 10, 2023 at 5:42 AM
    tacobuenos
    lonnie
    95 tacoma
    They seem fine. the shocks are about 10 years old though. They could be replaced but it clunks when I run over a pebble but not necessarily when I go over a speed bump. it's weird. The rear end is leaking at the pinion flange where the drive shaft goes in at the diff
  6. Mar 10, 2023 at 1:27 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    I'd try to rule out cheaper culprits first. Carrier bearing look alright? Remove, inspect, and re-grease rear drive shaft slip yoke yet?
  7. Mar 10, 2023 at 1:57 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Is it 4wd? If so, take out the rear drive shaft, and put it 4wd.
    Ultimately, if you think the pinion or diff grenaded some teeth you gotta pull the 3rd member and inspect it. you might find metal bits in the gear oil if you drain it. No amount of us guessing can tell what bearings might be bad in there.
    Abeyancer likes this.
  8. Mar 10, 2023 at 5:26 PM
    tacobuenos
    lonnie
    95 tacoma
    I had the drive shaft balanced and while out it was all greased up. But yea, I'm not ready to replace the diff yet. I'm still looking around
  9. Mar 10, 2023 at 6:00 PM
    Abeyancer
    Jimmie
    PNW
    At least draining and refilling the diff oil can give you some sort of indication on the heath of the internals.
    Any silver glitter=bad news
  10. Mar 11, 2023 at 1:26 PM
    tacobuenos
    lonnie
    95 tacoma
    I just changed it about 5,000 miles ago and it looked okay. it leaks around the pinion flange so it's fresh. lol
