Rear end conversion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kauaitoy88, May 20, 2020.
  1. May 20, 2020 at 10:56 PM
    Kauaitoy88
    Kauaitoy88 [OP] Active Member
    Tim
    Single cab 96 taco
    Need some help I have a 1996 4cyl single cab tacoma and I have 2003 v6 4door tacoma that I got for parts for my front clip conversion and I was wondering if I can install the rear end that has an elocker rear end on my 4cyl is this possible?
  2. May 20, 2020 at 11:22 PM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    Is the 4 cylinder 2.4 5 lug or 2.7 6 lug?
  3. May 20, 2020 at 11:22 PM
    Kauaitoy88
    Tim
    Single cab 96 taco
    2.7 6 lug
  4. May 20, 2020 at 11:24 PM
    BikerinBlak909
    SoCal
    96 LT 5 lug
    It should bolt up except I believe the E brake is different though
  5. May 20, 2020 at 11:31 PM
    Kauaitoy88
    Tim
    Single cab 96 taco
    Would it affect the front when I put it in 4x4 or should the gearing be the same
  6. May 20, 2020 at 11:35 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    You need to find out what gears you have. Most trd off-road V6 trucks were 4.10 gears. Your front may be different. You don’t want that
