Rear End Freezing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Belfast Brian, Jan 6, 2018.
  1. Jan 6, 2018 at 7:01 AM
    Belfast Brian
    Belfast Brian [OP] New Member
    Brian
    2006 Toyota Tacoma double 4wd v-6
    none
    We are in a nasty cold snap and my rear tires are freezing up. When I back out of my driveway my rear tires allow that to happen ,but when I put it into drive the rear tires don't turn . After a few minutes ,I will try again either taking it out of 4wd and putting it into 2wd .Sometimes this works . This has only happened during this cold snap .Should I worry ? I have the truck parked in the garage now ,hoping this will help ,any ideas ?
  2. Jan 6, 2018 at 7:04 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    parking brake froze?
    NAAC3TACO likes this.
  3. Jan 6, 2018 at 7:35 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Maybe check your differential fluid. If low, it could be frozen.
  4. Jan 6, 2018 at 7:36 AM
    Clearwater Bill
    Billy
    Largo Florida
    Don't apply the ebrake. Chock the wheel if on a slope.
  5. Jan 6, 2018 at 7:54 AM
    Pigpen
    Dan
    Northwest Montana
    The parking brake cables have a rubber grommet at the rear hubs. It is known to rot and rust the cable due to water getting in. The freezing is your truck telling you that you need to replace the parking brake cable. At least it's not totally rusted. Yet.
  6. Jan 6, 2018 at 7:55 AM
    Clearwater Bill
    Billy
    Largo Florida
    Maybe. We don't have pics. :D
    Pigpen[QUOTED] likes this.
