rear end growling after dealer chg fluid...!!
Discussion in 'Technical Chat' started by budisit, Jul 5, 2010.
  1. Jul 5, 2010 at 10:44 AM
    budisit
    budisit [OP] Active Member
    Buddy
    white, long bed, TRD, dbl cab
    2008 Taco dbl cab, long bed. 64,000 miles
    Took truck to dealer cause grinding sound when turning slow speeds.
    Dealer says checked diff fluid and it was broke down, needed changed.
    I said to dealer....but didn't you just change the diff fluid at 60,000 miles only two months ago ? He says...."no we only checked the level".
    So he changed the fluid and added LSD additive. This helped and ALMOST took all the grinding sound out but not completely. It still grinds.
    I go home and check my receipt from two months ago at 60,000 miles and the dealer had charged me for rear diff fluid and LSD additive service. Owners manual says it is supposed to be changed at 60,000 miles and I was charged for this service but apparently it was never done.
    So I complained and they gave me my $$ back for the service done only a few days ago.
    Freakin' dealerships !!
    Anyway..........the rear end is still grinding some.
    Any help or opinions greatly appreciated.
    Thanks.........
    BUDDY
  2. Jul 5, 2010 at 10:48 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    You had a few typos I took care of it for you.... Good job on getting your money back. You should of asked them to show you how to check the fluid level.:rolleyes:
  3. Jul 5, 2010 at 10:50 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Mmmm that's not good. I've heard using the wrong fluid can produce odd sounds. What differential do you have? LSD? E-Locker?
  4. Jul 5, 2010 at 11:29 AM
    budisit
    Buddy
    It's LSD rear end. And as for what oil they used ? Probably the cheapest money can buy.
    Thanks for the typo fixes (stealerships). Man what a learning experience.
    Now I just hope I can get the rear end fixed okay. Perhaps I should have a private mechanic take a look at it?
    Could it be the front diff also ??
    I don't trust the 'stealership' (as you put it) anymore. So I'm on my own and looking for a plan as to what next. So you know. I am no mechanic. None, nada. I know how to drive pretty good but that's about as mechanical as I get.
    thanks,
    BUDDY
  5. Jul 5, 2010 at 11:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If the rear diff is groaning, they didnt add the propper amount of the LS diff addative. Make them do it again.
  6. Jul 5, 2010 at 11:40 AM
    huntinggunns
    huntinggunns Lifes a garden, dig it.
    Fred
    Oklahoma
    2014 MGM SR5 DC SB TSS 4x4
    In progress
    ^X2
    Chris is right. On my 07 I had the same problems and had to use 2 tubes of the BG additive. Just add a little more and then go to a deserted parking lot or field. Let the vehicle idle/go slowly as you make about 10 circles as tight as you can to the right. Then do the same making about 10 circles to the left. This will work the additives into the clutch packs on the LSD rear ends.
    Fred
  7. Jul 5, 2010 at 5:05 PM
    budisit
    Buddy
    Thanks gang....
    I went to a parking lot today and started some figure 8 circles. Only did a few but that seemed to help. I will continue. Whod-s-thunk....driving in circles would ever fix something ??!!
    So far so good. I should finish up the circle driving tomorrow and hopefully that will fix the problem.
    What a joke. Dealerships.
    Thanks all. I really appreciate your help.
    BUDDY
  8. Jul 5, 2010 at 5:25 PM
    huntinggunns
    Fred
    Oklahoma
    In progress
    Buddy,
    Don't forget to add a little more LSD modifier to the rear end and change the LSD fluid every 30,000 miles. :D:D PS: adding some rep would be great.
    Fred
  9. Jul 5, 2010 at 6:00 PM
    budisit
    Buddy
    Okay...just went to a parking lot.....spun in circles 10X both directions slowly.
    PROBLEM FIXED !!!!
    Yahoo !! Thanks tacomaworld.........stealerships bite it
  10. Jul 5, 2010 at 6:09 PM
    huntinggunns
    Fred
    Oklahoma
    In progress
    Buddy,
    It works every time. Remember, the friction modifiers in the gear lube break down pretty fast so change it at least every 30,000 miles. You can do it yourself and save a ton of money.
    Fred
  11. Jul 6, 2010 at 8:12 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  12. Jul 6, 2010 at 8:22 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
  13. Jul 13, 2010 at 5:35 AM
    Janster
    Jandy
    Lancaster, PA
    There are tons of modifiers out there. One dealership will use synthetic oils & one type of modifier, while another dealership will use dino oil and another type of modifier.
    What they don't mention - is what type of modifier. Like, type?
    Every oil or grease you use on/in your vehicle has a type - API standards, etc. They don't mention 'how much to use' either.
  14. Jul 13, 2010 at 5:52 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Maybe it's because Eaton won't even give a recommendation (at least to me) on the type of oil or modifier, only that it should be a mineral based oil and friction modifier should be used. Although you'd think that Eaton would be more willing to share info with Toyota.
    If you ask me the problem is with Eaton. I think they got themselves into trouble by making a recommendation that didn't work out and now they won't make any.
  15. Jul 13, 2010 at 8:00 AM
    BlueT
    NorthEast
    Ok but eaton does not produce anything that remotely looks like that LSD, hence I dont think its Eaton. Original factory one on tundra, mounted i n the same diff, where produced by HINO
  16. Jul 13, 2010 at 8:24 AM
    afd23a
    The Dynamo of Dixie
    So we talking about 2 different LSD's then? I was under the impression that the clutch type LSD used by Toyota are the Posi units built by Eaton which use carbon clutch packs.
    The one I plan on putting in is built by Eaton. I assumed that since the TRD Kazuma LSD's were made by Eaton, that the stock ones were too.
    How is the Hino LSD different?
  17. Jul 13, 2010 at 8:35 AM
    BlueT
    NorthEast
    here is the link to Pirate4x4
    According to post its completely different Unit
    http://www.pirate4x4.com/forum/show...t=toyota+differential+info+give+input+updates
    And Factory is much better IMHO :D
    So suckers who sold theirs can cry the river :rolleyes:
  18. Jul 13, 2010 at 10:13 AM
    afd23a
    The Dynamo of Dixie
    Good info there. So OEM is 4 pinion and Eaton aftermarket is 3 pinion. I would think that the extra pinion would make the OEM stronger too, although both Hino and Eaton make products for heavier duty trucks so I'd hope they know what they're doing.
    Too bad Toyota can't service their own LSD's right sometimes.
  19. Jul 13, 2010 at 12:07 PM
    Janster
    Jandy
    Lancaster, PA
    Yeah.... It's a no wonder they got rid of them and went with Auto LSD. :rolleyes:
