Rear End Hopping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by college budget, Jun 15, 2016.
  1. Jun 15, 2016 at 1:12 PM
    college budget
    college budget [OP] Member
    Kurt
    Orange county, Ca/ Flagstaff, Az
    06 prerunner black SR5
    bilstein, fox, toyo 33's on black fj's, cali raised pods rago fab, leer shell
    I apologize if this is already a thread I could not find this exact issue. The last three days I have noticed the truck at any speed has started to bounce up and down.(all motion is felt though out the truck and not coming from the steering wheel) I had the tires balanced twice, alignment done, drive shaft and U joints checked and a couple other things. It seems to be coming from the rear end. Only thing I had done to the rear was about a month ago for the leaf spring recall. When I was under I noticed the left springs and bracket seemed bent or twisted. Anyone else have this problem?
  2. Jun 15, 2016 at 1:19 PM
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    That spring hanger looks derped..o_O
    Throw a level on it and check to see for sure. That could be causing your hop.
    RJM
  3. Jun 15, 2016 at 1:20 PM
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    if it just keeps bouncing after hitting a bump then your shocks are shot.
  4. Jun 15, 2016 at 5:47 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Yeah that hanger looks cock-eyed. I would think that would cause some issues. Get a BFH and straighten it.
  5. Jun 15, 2016 at 5:51 PM
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    If her rear end is a hoppin', don't come a nockin'!:devil:
  6. Jun 15, 2016 at 9:40 PM
    college budget
    Kurt
    I feel like i'm getting axel wrap but I have new leafs...
  7. Jun 15, 2016 at 9:44 PM
    college budget
    Kurt
    Its a constant motion going up and down seeming to come from the rear, not just after going over something and then having a continual motion, unfortunately.
  8. Jun 16, 2016 at 7:06 AM
    WOTaco
    Just a shot in the dark here but try taking some measurements with a tape. Maybe distance between front end of the leaf springs compared to the distance between the back end of the leaf springs. I would assume they should be the same(parallel). I guess you could also take some measurements off of the rear axle and make sure it's not out of square. You could also pull out your rear shocks and compare how they feel when you try to compress them, you'll know right away if one is blown out.
  9. Jun 16, 2016 at 7:33 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    My guess they don't have the spring pin in the hole in the axle on the left side.
  10. Jun 16, 2016 at 8:00 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I see original black shocks on an 06.... its your shocks man, dont over think it.
  11. Jun 16, 2016 at 8:02 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    agreed. get up on the bumper and hop up and down and get it undulating..jump off..if it keeps going, order new shocks.
  12. Jun 16, 2016 at 1:47 PM
    college budget
    Kurt
    Took them off and yeah defently time for a replacement
  13. Jun 16, 2016 at 4:14 PM
    HB Taco
    Curt
    I have a pair of original Yellow Bilstein shocks (TRD Off road pkg) off of my truck I might part with. They are like new only 4k mi when I switched to 5100's. If you can come to HB even better. Msg me if interested.
  14. Jun 16, 2016 at 6:15 PM
    college budget
    Kurt
    Going with Fox, thanks for the offer though
