Rear end howl/whine at 60mph....NO MORE HOWL!! issue solved.....ITS BACK!!!!! :(
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chiloquin_Car_Care, Mar 6, 2019.
drive with the howl/whine?
  1. hell no....thats annoying
    16 vote(s)
    38.1%
  2. hell no....thats dangerous
    9 vote(s)
    21.4%
  3. who cares....jjust turn up the tunes & drive
    17 vote(s)
    40.5%
  1. Mar 25, 2019 at 10:39 AM
    #101
    Chiloquin_Car_Care
    Chiloquin_Car_Care [OP] homie dont play that
    Oregona
    2021 voodooblue DCSB 4x4 3.5l v6
    nada....maybe a license plate one day & BA bumpers
    I really appreciate your input on this
    when you say 'carrier bearing' I suspect you are referring to the driveshaft center support bearing (donut)...is that correct?
    it sounds like you are going through the same trouble shooting as me
    I replaced both front & rear wheel bearing but the howl persists....that's when I started to look at the drive train
    isolated the issue by doing the remove rear DS, 4HI, & test
    furthermore, I scoped the diff before reinstalling DS & heard rumbling at where the pinion bearings are located
    (truck's rear axle was elevated off ground & rear wheel turned by 2nd set of hands,
    while I was under truck listening with scope at various points of the rear axle/diff housing)
  2. Mar 25, 2019 at 10:49 AM
    #102
    Cozza
    Cozza Hi
    Corey
    Denver area, CO
    GX
    Ah, yes thats correct. Center bearing. I plan on dropping the DS this week and testing.
  3. Mar 25, 2019 at 10:53 AM
    #103
    Chiloquin_Car_Care
    Oregona
    keep the thread posted...very interested in the test results :)
    btw- it is a truly unique experience running the taco in FWD mode...the torque steer is wild....you can really feel the power of the motor through the steering...crazy, weird, fun
  4. Mar 29, 2019 at 4:01 AM
    #104
    Cozza
    Cozza Hi
    Corey
    Denver area, CO
    GX
    Well, removed the driveshaft last night. Drove it into work in FWD, forgot how wild it actually is!
    NO CHANGE. I still have a noise from 60-75ish MPH during accel, coast, and decel. It's the worst at 62.5 Also a nice decel noise between ~30-40, which I guess isn't the needle bearing since I was in fwd.
    Next steps are to have the tires rotated and balanced, see if there's any change there.
    Maybe I got a bad hub bearing?:annoyed:
  5. Mar 29, 2019 at 6:46 AM
    #105
    Tacomax4
    Tacomax4 Well-Known Member
    2012 DCLB TRD Sport 4x4
    Lucky you, it’s probably the hub bearing or tires
  6. Mar 29, 2019 at 6:49 AM
    #106
    Tacomax4
    @Chiloquin_Car_Care
    I’ve got the exact same howl in my diff in my 2012 at... get this... 58,000 miles. Really sucks that the powertrain warranty only lasts 5 years or else I’d be at the dealer right now. Can’t wait to see if your new third member fixes it, because this howl is so flippin annoying and I just wanna get rid of it.
    EDIT: I just scored a used rear diff off a 2014 with only 12k miles on it. I'll install it next week and see how it goes
    Chiloquin_Car_Care[OP] and Cozza like this.
  7. Mar 29, 2019 at 3:56 PM
    #107
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    @Cozza your symptoms sounds very similar to mine.
    I've had this noise for a while and tires didn't fix it. 2 new wheel bearings, CVs and the ECGS bushing. And it's still there. Took the rear driveshaft out and it's still there. Changed oil in both diffs and TC.... Still there. Tranny filter and refill... You guessed it, still there. Dropped the rear drive shaft as well...
    I'm thinking pull the from driveshaft, drain the front diff and pull the CVs out. Them put rags in the holes and take it for a spin.
  8. Mar 29, 2019 at 6:59 PM
    #108
    Cozza
    Cozza Hi
    Corey
    Denver area, CO
    GX
    I have a recently rebuilt CV due to a torn boot and an original CV. I had the same thought about the front driveshaft too - maybe a u joint in that is bad
  9. Mar 31, 2019 at 8:40 AM
    #109
    Chiloquin_Car_Care
    Oregona
    I only get the howl on decel or very light throttle on flat road (around 50-70mph, most audible at exactly 60mph)
    I dont get the howl on normal accel/hard accel at 50-70mph
    I think this a major factor in our similar, yet different issue
    good luck on isolating your issue
  10. Mar 31, 2019 at 8:41 AM
    #110
    Cozza
    Cozza Hi
    Corey
    Denver area, CO
    GX
    Ive been playing around in FWD and noticed a vibration when giving it hard throttle... leads me to believe it may be something in the front driveshaft
  11. Mar 31, 2019 at 8:42 AM
    #111
    Chiloquin_Car_Care
    Oregona
    please update after you do the swap!
    thanks for your insight
  12. Mar 31, 2019 at 8:45 AM
    #112
    Chiloquin_Car_Care
    Oregona
    I would try testing the ujoints in the front shaft
    put in 4hi & shift between D & R (keep foot on brake while doing so) the truck should not jerk
    maybe try this with rear shaft removed so all torque goes to front shaft & you can really feel any clunk while going back & forth from D TO R
  13. Mar 31, 2019 at 9:41 AM
    #113
    Muddinfun
    Muddinfun Well-Known Member
    Don't do this. The outer CV joint holds the wheel bearings together. With it removed, there is the possibility of the wheel bearing coming apart.
    landphil, Larzzzz[QUOTED] and Cozza like this.
  14. Mar 31, 2019 at 3:48 PM
    #114
    Larzzzz
    Larry
    MA
    @Muddinfun thanks. I haven't done it yet. Guess I'll just pull the front ds off.
  15. Apr 1, 2019 at 9:55 AM
    #115
    Chiloquin_Car_Care
    Oregona
    ECGS just shipped my replacement 3rd member.....HAPPY TACO DRIVER HERE
    cant wait to do the swap
    Larzzzz and Tacomax4 like this.
  16. Apr 1, 2019 at 9:59 AM
    #116
    Chiloquin_Car_Care
    Oregona
    & it was $1170...yikes!
    I get core value back on my old one when I return it, putting me at around $800 final price
  17. Apr 2, 2019 at 5:52 AM
    #117
    yank
    yank Member
    Tom
    Cook, MN
    09 SR5 V6 Auto Barcelona Red, 22 off road AC AG
    My 09 started howling at 75000. Still howling at 125000. I'm guessing it will be drivable for many more miles, but if your carrier swap works, I may have to follow suit for peace of mind and silence.
  18. Apr 2, 2019 at 7:48 AM
    #118
    Chiloquin_Car_Care
    Oregona
    thanks for your input
    I noticed mine howling at 295k miles,
    but I dont know how long it had been howling prior to that...could have been there for 100,000 miles, lol
    & I just didnt notice because the howl is so subtle
    I got tuned into the noise because of a different bearing issue at 295k (front diff needle bearing)
    once I swapped the needle bearing for the ECGS bushing, I started paying attention to sounds from under the taco & discovered the 'HOWL'
    cant wait to get my ECGS rear diff! (maybe monday????? go UPS go!)
  19. Apr 6, 2019 at 2:47 PM
    #119
    Norton Guy
    Norton Guy Well-Known Member
    North East
    2011 Double cab SR5 Sport
    My 2nd gen was howling @ about 140,00, pretty easy diagnosis when I jacked it up and spun the wheels the left front had a nasty rumble. New hub / bearing made it go away.
  20. Apr 6, 2019 at 3:16 PM
    #120
    Chiloquin_Car_Care
    Oregona
    Im unsure if you read the whole thread, but I changed all 4 wheels bearing & the howl persists....I have isolated down to the rear diff pinion bearings or the race they run in as the cause of my howling....monday I get a rebuilt 3rd member from ECGS & cant wait to install it
