rear end interchange
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2013 sport guy, Jan 7, 2020.
  1. Jan 7, 2020 at 2:47 PM
    2013 sport guy
    2013 sport guy [OP] Member
    I have a 2013 TRD Sport that I need to swap out my rear end in. 3rd member is fine, axles good, all i need is the rear end housing itself. ive found a couple 2nd gen, but they are 2wd, and my truck is 4wd. can i use a 2wd rear or does it need to be 4wd? Thanks in advance!
  2. Jan 7, 2020 at 2:48 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    As long as its a 6 lug non e locker axle you are good to go. Are you sure the axles are good, bent housing can mean bent internals.
  3. Jan 7, 2020 at 3:02 PM
    2013 sport guy
    I am going to go ahead and grab some axles just in case, they are fine, but enough impact to bend the housing can't be good for the internals.
  4. Jan 7, 2020 at 3:28 PM
    Muddinfun
    Muddinfun Well-Known Member
    Any machine shop worth anything can put an axle shaft in a lathe between centers, run a dial indicator on it and tell you if it's bent. Takes less than 5 minutes.
    DG92071 likes this.
  5. Jan 8, 2020 at 4:45 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Do we have the same axles as first generation Tundras? Heard they were the same, but with different gearing.
    If so, that should provide more options.
