Rear end is higher than the front?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SmokeyDP, Jul 28, 2010.
  1. Jul 28, 2010 at 4:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Looks like a custom made leaf pack..
  2. Jul 28, 2010 at 7:46 PM
    SmokeyDP
    SmokeyDP [OP] Well-Known Member
    Somerville, NJ
    03 Tacoma
    So from what I understand I can't really do much to lower the back, but I should get 5100's with new springs for the front to raise it up.
  3. Jul 28, 2010 at 7:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can pull one of those leafs out, and see what it gives ya. How much are you wanting to lower it?
  4. Jul 28, 2010 at 7:50 PM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    I'd have to measure but it looks like about 2"
    Whats involved with pulling a leaf?
  5. Jul 28, 2010 at 7:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Try removing the bottom leaf, and see what it does for ya. There is a write up on here ( A couple actually) that out line the dissasembly of the rear leaf pack. Do a search for AAL instal.
  6. Jul 28, 2010 at 8:07 PM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    I just found it. The only thing that is different from my setup is I have clamps that go fully around the leafs in this picture instead of just being open at the one end. I guess I would have to cut off the top two tabs to remove the one leaf with a grinder.
    http://www.scotts-basement.com/Gallery2/d/13326-2/IMG_0593.JPG
  7. Jul 28, 2010 at 8:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You may be better off having a shop do it for ya. You will have to grind off the spring clamps.
  8. Jul 28, 2010 at 8:10 PM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    This seems doable. I needed an excuse to pick up a grinder anyway.
  9. Jul 28, 2010 at 8:25 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I would personally lift the front. those struts look abused. or they just have alot of miles on them...
  10. Jul 28, 2010 at 8:28 PM
    747
    747 function > form
    1st Gen.
    off-topic post: look at your rear diff fluid if you think the former owner towed w/it.
  11. Jul 28, 2010 at 8:31 PM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    I just changed the rear and transfer case fluid a few min ago actually. Was going to start the trans fluid then realized my racing jack only goes to 14" high and it was getting late.
  12. Jul 28, 2010 at 8:33 PM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    I want to eventually do that but if I can lower the rear for free I'm going to do that for now. At least until I solve my transmission whine.
  13. Jul 28, 2010 at 9:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Are you sure its the tranny making the whine, and not the power steering pump?
  14. Jul 29, 2010 at 3:24 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    It might be something someone would be willing to trade a 3 leaf pack for, depending on condition, of course. People are always wanting to up their rear a little after putting on a lift in the front. Where are you located?
    I'd probably opt for a cheap spacer lift as opposed to dropping the rear.
  15. Jul 29, 2010 at 5:53 AM
    #35
    SmokeyDP
    Somerville, NJ
    03 Tacoma
  16. Jul 29, 2010 at 5:54 AM
    #36
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    Not a bad idea. I updated my profile on the left with my location.
  17. Jul 29, 2010 at 7:37 AM
    #37
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Actually, I don't get it. A Tacoma is supposed to be a truck. Generally, the purpose of a truck is to carry something in the bed, thus lowering the back end to some degree. I would not want a truck that sags when you carry something, so I think the back end SHOULD be slightly higher when unloaded. Personal opinion, and I'll bet that's why they come that way.
  18. Jul 29, 2010 at 8:13 AM
    #38
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The OP's truck has a different leaf pack than what came from the factory. It sits too high for his personal taste.
