Rear End Lift Questions
Discussion in 'Suspension' started by bigfro, Sep 1, 2009.
  1. Sep 1, 2009 at 4:58 PM
    bigfro
    bigfro [OP] Well-Known Member
    Denver
    13 TRD Sport DCSB
    Billy 5100 @ 1.85 + shim on L for Taco Lean Icon AAL 3 pack w Rear Overload Removed
    Ok Everybody Here is my Situation.
    Truck 2005 Taco TRD sport 4.0
    Equipment installed
    Front
    2.75 Ready Lift
    Bilstein 5100 set at 0"
    Rear
    Toytec 2" AAL
    Ready Lift 1" block
    Bilstein 5100
    PRE-TSB (Toyota wont help me out (64k on truck -- Just bought it)
    When I bought the truck before lifting it the truck sat .5" higher in back.
    When you would look at the leaf's 70% of the leaf was sitting on the overload. one of the rear shocks was blown. (Think the previous owner was towing alot.. Should have seen that before I bought the truck but I didn't)
    So here is what I did.
    I installed the Readylift kit up front with new 5100's and 1" blocks in the rear. The truck was far from level (front sat 1.2" higher at least)
    So I elected to go get 2" AAL from Toytec (they are right down the street from me :p )
    Now the truck sits good (about 1.5" higher in back which looks fantastic compared to sagging butt..)
    I don't plan to 4x4 alot. If I do i very rarely get wheels of the ground.
    Here are my concerns.
    1.) I have a very small driveline vib at low rpm starts then I can't feel anything, well at least to 80mph (haven't gone faster yet)
    2.) U joint wear? Should I worry? Should I shim? Can I shim with blocks??
    3.) Shock length. Rides fine over potholes, bumps etc. If i hit a speed bump hard I can feel the shocks max out. Do I extend them? If I do, do i extend break lines?
    4.) Safety for mild driving and towing a light trailer with maybe a 4wheeler and camping supplies 3 times a year, and 4x4 maybe 10 times per year, should I worry about the blocks breaking?
    5.) do the AAL settle at all after a break in period if so how many inches?
    My thoughts.
    Truck rides great in the front. A bit stiff in the rear (pre TSB, and AAL, 5100's can do that I am guessing)
    If you look at the shot of the leaf you can see the wear.
    My other major issue...
    The transmission...
    6speed stick.
    I have issues every now and then of it popping out of gear in 1st.
    I changed the fluid and it was overfilled by quite a bit, now it very rarely happens, but the trans is noisy ( I can hear it in the cab ) The plug had quite a bit of metal bits stuck to it (because its a magnet) More so than the diff or transfer case. Can I run a thicker gear lube to quiet it up? or should I be preparing for the worst? I have put 4k on it and it hasn't changed condition at all.
    Thanks for the help! P.S. This is my first post! :)
  2. Sep 1, 2009 at 5:07 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    As for the rear bottoming out, mine was doing that too. I had OME rear shocks and the tsb pack leafs. I swapped my leaf packs out with the 3" All Pro ones and now its fine. I highly doubt its the shocks. It's probably the leafs.
  3. Sep 1, 2009 at 5:09 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Why don't you drop the front spacer and just put the 5100's at 2.5? I just don't like blocks at all.
  4. Sep 1, 2009 at 5:11 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Good idea. Ditch the spacer, set billys at 2.5" and get rid of the rear blocks. Then shim if necessary to get rid of the vibs
  5. Sep 1, 2009 at 5:11 PM
    bigfro
    Denver
    13 TRD Sport DCSB
    Taking out the front spacer and setting the bilstein's at 2.5 and removing the rear block is an option. ( The readylift kit jumped my truck up 3" though and rides great) Plus I had to get the thing aligned 3 times before it tracked correctly. If I pull the spacer, and set the coil's at 2.5 it would lower the front a tad and the rear would come down a tad. The ride would be better but it wouldn't be as high... That is a great thought though.... Plus the alignment shop would hate me if I came back....
  6. Sep 1, 2009 at 5:14 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Most people hate the ride that the spacers produce. You might find that taking them out and using the billys for lift will ride a bit better. You will only lose 1/4" up front. You could always buy a bit larger tire next time.
  7. Sep 1, 2009 at 5:17 PM
    bigfro
    Denver
    13 TRD Sport DCSB
    Does anybody know if it is possible to run the blocks with a shim? or is that a bad idea? I really like how tall the truck is now with the spacers and the blocks+AAL in the rear I am just concerned that this could lead to a failure. Take a look at the pics, the rear springs did sag before I did the lift, thats why i went with both the AAL and the blocks.. I am trying to stay cheap for awhile... Anybody have any thoughts on the trans issue? Also are the blocks + AAL a really bad Idea?
  8. Sep 2, 2009 at 4:49 PM
    bigfro
    Denver
    13 TRD Sport DCSB
    All Right!!!
    Truck is all fixed up, here is what I did.
    I took out the 1" blocks and replace with 3* shims from toytech, Rear of truck dropped down about .75". Truck sits about .5" higher in back and rides fantastic.
    I then changed out the gear lube to a 75-90 and added a couple doses of friction modifier for LSD's. Tranny shifts way better, no noise, and doesn't slip out of gear... Who would have thought...
    Anyways Looks good. I have a couple of 1" blocks and some U bolts laying around now, the blocks are perfect but the u bolts I wouldn't re-use. Anybody want them all for 25 bucks?
  9. Sep 2, 2009 at 5:37 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Cool. Did the vibes go away?
  10. Sep 3, 2009 at 9:42 AM
    bigfro
    Denver
    13 TRD Sport DCSB
    I would say they have gone away about 85%. Visually I can see that the shims placed the drive line in almost the exact same position it used to be.
    I can feel the vibes until 1600 RPM only in first gear just when starting. It could also be axle wrap, or clutch, either way its very very small, only i have notice it.
    So my setup is now as follows
    2005 TRD Sport Access Cab (Red)
    Intake
    Custom Catback
    Billy 5100 Front
    Billy 5100 Extended Rear
    Front Readylift Spacer 3"
    Rear Toytec AAL 2"
    Rear 3* Shims
    Repainted Frame Black (had some surface rust)
    Changed Tranny Oil GL5 -> Added 2 doeses of LSD additive SMOOTH SHIFTING!!!!!!
    Re-clutched Rear Diff running Royal Purple stronger springs.
    Iridum Plugs
    Added 6 Disc Player
    TRD Seat Covers
    TRD Shift Knob / Pedals
    Black Nose Bra, Not full mask until winter.
    Re greased u-joints, leaf packs.
    16" Wheels w 265 75 R 16 Tires (so i didn't have to trim fender wells)
    Upcoming,
    Quick disconnects for swaybar
    Add Rear swaybar w quick disconnects
    Headers
    Amsoil custom passive filter setup
    Ubolt flip
    LSD for front diff
    some sort of tonneu cover
    I love my Toys....
    Post Complete!
  11. Sep 3, 2009 at 11:45 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Awesome!
  12. Oct 2, 2010 at 5:44 PM
    2011TacoSport4x4
    2011TacoSport4x4 Well-Known Member
    Clyde
    Offutt AFB, Nebraska
    2011 TRD Sport DC 4x4 OME 3" lift
    OME 3" lift, Flowmaster exhaust, K&N Intake, bestop, ARB Locker, 4:56 gears, ARB Deluxe bumper, Warn 8000lb winch, Synthetic line, Rock sliders, exhaust relocation done, All Pro standard 3" leaf packs, Timbren Bump stops, Extended brake lines, Pioneer dual din DVD, Pioneer door speakers, Ultra Gauge, BAMF Lower LCA Skids.
    I switched from 3 degree to the 2.5 and my low speed vibs are gone. I also have the 2" aal in the rear.
