rear end noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cline, Jan 6, 2013.
  1. Jan 6, 2013 at 8:52 PM
    cline
    cline [OP] Member
    ethan
    Covington, va
    07 tacoma SR5
    3in pro comp lift 285/75/16 Cooper discovery stt tires
    My rear end is making a squeaking noise only at higher RPMs . Ive been off roading a whole lot lately because of hunting season and spinning alot because where i hunt at is pretty rough. Could anyone tell me whats wrong
  2. Jan 6, 2013 at 11:10 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    off that? no
  3. Jan 6, 2013 at 11:20 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 4x4> 03 SR5 4x4 total> 14 Crewmax TRD
    Had tons on the old Taco's.... new Tundra is pretty stock
    x2
    Too vague. OP, can you describe the sound/condition it occurs at better?
  4. Jan 7, 2013 at 5:44 AM
    cline
    cline [OP] Member
    ethan
    Covington, va
    07 tacoma SR5
    There aint to much to describe. It makes a squeeking noise, and the higher rpm's that i run, the louder the sound gets
  5. Jan 7, 2013 at 5:49 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    check your u joints then wheel bearings
  6. Jan 7, 2013 at 5:53 AM
    Gearheadesw
    Gearheadesw Well-Known Member
    Davenport Fl
    2016 GMC 2500hd
    some
    Pinion bearing on one of your diffs?
  7. Jan 7, 2013 at 6:03 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    being an 07 its more probable its the other two, im waiting for OP to reply back
    also whats the whining sound like, does it increase/decrease with turns/ acceleration/deceleration? is it squeak squeak squeak how many miles on the truck
  8. Jan 7, 2013 at 8:59 AM
    cline
    cline [OP] Member
    ethan
    Covington, va
    07 tacoma SR5
    It sounds like pieces of metal hitting together. It only does it if im accelerating, doesn't do it in turns or decelerating . And 54,000 miles
  9. Jan 7, 2013 at 9:02 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2012 Lifted Tacoma Doublecab (SOLD)
    4" zone offroad suspension lift modified with Rcd bilstein front shocks w 1/2 spacer for 5.75" front lift and allpro expo leap pack with 2" block for 6" rear lift, extended length stainless brake lines front and rear, beefed taco carrier bearing drop brkt, 1.25 alum driveshaft spacer, avid lightbar powdercoated w 2 9" led lights, , amp research power steps, anderson aluminum drop hitch, ss grill insert w color matched grill, color matched door handles, color matched rear bumper, color matched pop n lock tailgate handle, 2012 sport mirrors added, color matched mustang hood scoop, borla ss exhaust, extang full tilt tonneau cover, windows tinted darker,oem roof rack, 2014 touch screen radio w navigation, infinity kappa speakers front and rear, rockford fosgate amp, 2 10" kicker subs, 2tone katzkin leather, hydro dipped interior parts, inalfa 925 power moonroof, lexus F sport shift knob
    Check your fluid level in the rear end
  10. Jan 7, 2013 at 9:39 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    defineately sounds like a ujoint
  11. Jan 7, 2013 at 11:11 AM
    cline
    cline [OP] Member
    ethan
    Covington, va
    07 tacoma SR5
    Alright thanks alot y'all, ill have to get it check out
