Rear end of truck slams hard on bumps with new billes 5160
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tovar28, Feb 10, 2014.
  1. Feb 10, 2014 at 8:45 PM
    Tovar28
    Tovar28 [OP] Well-Known Member
    David
    Chino,California
    05 prerunner TRD sport
    bilstien 5100s in front @ 1.75 bilstien 5160 in rear,general HD 4 leaf pack, 20% tint in front 5% rear, 40 inch led bar ,Kc daylighters , Aries bully bar , aries side steps ,black housing headlights ,factory roof racks ,snugtop camper shell, plastidip rims, bfg ko2 tires
    I just installed a set of new rear billstien 5160 shocks and went for a test run, I went over a speed bump and the rear end slammed pretty hard I was wondering if it would be that the rear leafs are worn out or the shocks don't work? (Will install a set of 5100s in the front tommrrow )
  2. Feb 10, 2014 at 8:46 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    Sounds like they are not long enough. This happened to me when I put on my Donahoes years ago.
  3. Feb 10, 2014 at 9:22 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    did it slam on compression or extension?
    if compression did you get the extended shock length? if so thats probably why.
  4. Feb 11, 2014 at 6:26 AM
    Tovar28
    David
    Chino,California
    It slammed on compression and I got the stock hieght shock
  5. Feb 11, 2014 at 6:27 AM
    Tovar28
    David
    Chino,California
    They were the same size as the stock shocks
  6. Feb 11, 2014 at 8:05 AM
    nd4spdbh
    SoCal
    Do you still have the bump stops in ?
  7. Feb 11, 2014 at 8:34 AM
    Tovar28
    David
    Chino,California
    Yup I still have the stock bump stops
  8. Feb 11, 2014 at 8:50 AM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    That makes no sense to me. I know its not the collapse length because these actaully collapse a hair more than the 5100 do (5160 = 13.84" & 5100 = 14.02" collapsed)
    Sounds like maybe something is wrong internally. I thought the valving is the same as the 5100s so there should be no difference on compression.
    You happen to buy these used?
    If new I would contact the comp you bought them from and discuss the situation.
    You can always do a side by side.... manually compress both to see how they differ on compression.
  9. Feb 11, 2014 at 9:53 AM
    Tovar28
    David
    Chino,California
    I was looking under the. Truck and used a little black rubber seal or something that moves on the shock rod and went over the same bump and it looks like the truck hits the bump stop before the shock reaches its full compression would it be the leaf springs in that case?
  10. Feb 11, 2014 at 1:30 PM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    Jump up and down in your bed. Is it soft? Can you hear the shock compressing? If all you get is a thud or travel fast and limited you have a bad shock, the wrong shock, or your leafs are crap and banging the bump stop.
  11. Feb 11, 2014 at 5:24 PM
    Tovar28
    David
    Chino,California
    I think my leafs are crap would you guys know a good leaf pack to put on and leave it at stock height and have a good ride
