Rear end of truck too high without load..
Discussion in 'New Members' started by eligo9, Dec 31, 2017.
  1. Dec 31, 2017 at 6:12 AM
    eligo9
    eligo9 [OP] New Member
    susie
    2008 Tacoma
    Lift kit
    After installing lift kit and new springs(2 years ago) my truck is fine with a heavy load, but without it, the back is too "light". In ice and snow Im skidding all over..have 6 sand bags in there, but wondering if theres a better way to even out the weight?????
  2. Dec 31, 2017 at 8:34 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Welcome!
    If you can describe what lift was installed, we could assist with a recommendation.
    inwood customs likes this.
  3. Dec 31, 2017 at 9:28 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW! Are you not 4x4? A tire upgrade would help.
  4. Dec 31, 2017 at 9:32 AM
    su.b.rat
    su.b.rat broken truck
    sounds like you need more sand bags if you've got nothing else. if it's an ongoing problem then look into better tires. but if weight distribution is your problem, then adding bed load is the solution in a pickup.
    also just realized if you're bouncing a lot back there then you may also look into softening the suspension but that's a longer term and more expensive solution. happy New year
  5. Dec 31, 2017 at 10:05 AM
    eligo9
    susie
    2008 Tacoma
    Lift kit
    I got some heavy duty springs and lift kit from Old Man Emu so i can carry large loads..That is all I remember about that..I have AT Grabber tires which are fairly new..someone mentioned sone kind of air lift in the front..any thoughts? THANKS!!
  6. Dec 31, 2017 at 10:12 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Welcome to TW. What kind of air pressure are you running? It's -33C here so I purposely increase air pressure to compensate. I've got the same tires & absolutely no problems here.
  7. Jan 1, 2018 at 6:39 AM
    Hunt4Fun
    Hunt4Fun Well-Known Member
    Jack
    2010 Tacoma DoubleCab Base model
    Bedrug, Viper alarm and remote starter, Access tonneau cover, Low off road 3/1 suspension lift, locking tailgate.
    Tire chains are a lot of work, but if you need them, you need them.
  8. Jan 1, 2018 at 6:46 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Look up your receipts or contact your vendor. As Matt says, P/N's reveal a lot.
    Aaah... beautiful downtown Winterpeg; a train track runs through it.
    ... and it's a balmy -24*C here.
    :canada:
    FastEddy59[QUOTED] likes this.
