rear end problems
Discussion in 'Toyota Trucks & SUVs' started by tickle, Nov 1, 2013.
  1. Nov 1, 2013 at 9:36 PM
    tickle
    tickle [OP] New Member
    kingston, ontario
    1992 Toyota Pickup
    3 inch body lift, 16 inch rims,265/75R16 tires
    I recently purchased a 1992 Toyota Pickup. I really love it but the rear end went in it. I have been checking wreakers in my area and no one has anything. My truck is 3 Litre V6 5 speed 4 wheel drive. Has 456 gear ratio. I think pinion is 9 and ring gear is 41. I just found a cheap 1993 Toyota T100, does anyone know if the rear end will work in my truck. Thanks for any help you can give me. Getting very frustrated.
  2. Nov 1, 2013 at 9:55 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I believe it will provided the gear ratio is the same.
  3. Nov 1, 2013 at 9:55 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Why not just rebuild the rear?
  4. Nov 2, 2013 at 7:16 AM
    tickle
    kingston, ontario
    1992 Toyota Pickup
    thanks for the info you both provided. Just trying to get my truck up and running as fast as possible. Looked into getting it rebuilt will cost more than I can afford right now. I can get that whole other truck cheap and have extra parts if I need them.
  5. Nov 2, 2013 at 7:37 AM
    scocar
    scocar Patron of the Farts
    Here, see if this gives you what you need. At first glance, it may be a no.
    http://home.4x4wire.com/erik/diffs/
  6. Nov 2, 2013 at 1:46 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Get a price from a transmission shop a lot of them do ring and pinion cheaper than anyone else
  7. Nov 4, 2013 at 5:50 PM
    tickle
    kingston, ontario
    1992 Toyota Pickup
    Thanks again I was at the dealer they told me that the t100 rear end will not work but if I was to change both front and rear diffs would that work ?
    Or by sounds of it from reading that link if I find a 4 cylinder rear end with 4.56 It should work thanks again in advance
