Rear end questions
Discussion in '4 Cylinder' started by 0uTkAsT, Apr 19, 2011.
  1. Apr 19, 2011 at 9:42 PM
    0uTkAsT
    0uTkAsT [OP] Gunslingin' Gearhead
    Josh
    Gilbert, AZ
    Rock Flinging Expo Turd
    Stuff that makes it easier to run over other stuff.
    Hey all, still kinda new to Tacomas and I'm wondering if the LSD from an 05+ TRD Sport is able to be swapped in to a 06 non-TRD truck without changing out other parts? i.e. is the differential itself the only difference or are the housings, axles/splines, etc. specific to one rear end or another?
    Also, what kind of LSD do the TRD Sports have (i.e. are they electronically actuated or are they a simple cone or clutch type, etc), and what gear ratio are they (or does it depend)? My 4X4 2.7L 6-lug 5-speed is 4.10 geared, so the TRD would have to be the same for this to work.
    If there's any variables to be considered between differentials, what can I look for and where to find the info I need?
    Thanks so much for the help guys!
    (FWIW I'm trying to find a totaled TRD Sport to steal the rear diff out of for a cheap LSD upgrade)
  2. Apr 19, 2011 at 9:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    It will fit.
  3. Apr 19, 2011 at 9:52 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Your idea should work.
    Not sure on the gearing but believe it is 4.10:1 (of course the effective ratio would depend on your tire size also).
    The LSD is electronically controlled.
    Strike that. I was thinking of the full locker rear dif on the TRD package, which is electronic. No idea on the LSD? The full locker is the real deal!
  4. Apr 19, 2011 at 9:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The LS Diff is a mechanical type on the 05-08 trucks, Dwight. He's talking about the TRD SPorts, not the TRD Off Road that has the E locker. And as far as gearing goes, he can swap his Ring gear onto the LS carrier with no issues. :)
  5. Apr 19, 2011 at 10:00 PM
    mountainwolfpup
    Vancouver, WA
    Ahh yes Chris. Thanks. You are correct. I was thinking of the full locker on the TRD Off-road. Duh.
  6. Apr 19, 2011 at 10:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  7. Apr 19, 2011 at 10:08 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    I was told by the dealer that 4cyl diffs have a different axle spline count from the v6 diffs.
  8. Apr 19, 2011 at 10:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Many dealers have no idea what the Auto LS Diff is either. Everything I have read says the LS Diff fits the 8.4" housing. No mention of engine size.
  9. Apr 19, 2011 at 10:13 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    True...
    I just say that because when I had my 4cyl I was looking into finding a true LSD third member. I talked to my parts guy (life long off roader) and he immediately told me I would have to swap the axles also.
    He looked it up on the computer and showed me that 4cyls use a lower count spline on their axles (I don't remember the spline counts).
  10. Apr 19, 2011 at 10:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats true for the 5 lug Tacomas, but IIRC, all the 8.4's are the same.
  11. Apr 19, 2011 at 10:30 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You know, I bet your right... I bet he was thinking 5 lug.
    Who dare question chris4x4? :D
  12. Apr 20, 2011 at 9:56 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    If your looking for more traction from a LSD swap, it would be easier to just drop in a ARB locker I would think. Not sure the difference in price to get the parts needed and installation costs for the LSD vs just dropping in an ARB Locker, but you would have arguably a larger and stronger rear end then the E-locker, with way more traction then the LSD will ever offer. :cool:
  13. Apr 20, 2011 at 6:06 PM
    0uTkAsT
    Josh
    Gilbert, AZ
    You guys are awesome, thanks for the info!
