rear end questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nolanjohnson12, Jun 17, 2014.
  1. Jun 18, 2014 at 10:05 AM
    Manwithoutaplan
    ID
    I think they only come in one set and that is 3.73.
  2. Jun 18, 2014 at 10:07 AM
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    If you look them up on carpart.com it ask if you have 3.73 or 4.10
  3. Jun 18, 2014 at 10:08 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    3.73's for v6's 4.10's for 4 cyl
  4. Jun 18, 2014 at 10:09 AM
    Manwithoutaplan
    ID
    Thank i know that. I figured he had v6.
  5. Jun 18, 2014 at 12:30 PM
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    Just did this in my tacoma, put the 3.73 gears from East Coast Gear supply in my truck its an 8.4 Rear. You can get whatever gears you want from them and they build a great product. really easy to put in and only took my dad and I 2-3 hours without a lift. Also great customer service. They have ones for lockers too.
  6. Jun 18, 2014 at 2:39 PM
    TheGoat
    Justin
    Greenville, SC
    I didnt know that was the difference.
  7. Jun 18, 2014 at 2:44 PM
    Manwithoutaplan
    ID
    yea the 4.10's are to make up for the less power of the 4 cycle engine.
  8. Jun 18, 2014 at 3:10 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Why didn't Toyota offer a locker with the 4 cyl Ex. cab TRD? Why didnt they offer a 5 speed in a Prerunner? Why couldn't you get a V6 or the TRD package in a reg cab? Lots of things Toyota did doesn't make sense
  9. Jun 18, 2014 at 3:15 PM
    smmarine
    Melbourne FL
    Cause it looks better then a base taco. Can haul more weight, and go more places then a base taco
  10. Jun 18, 2014 at 3:20 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Is there a thread that u've posted on that u havent bashed prerunners or diesel?
  11. Jun 18, 2014 at 3:20 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Nope again. The ring is different on the number of bolts holding it to the carrier but the same otherwise. Shit's been beat to death and nobody gets it. The E-locker carrier is weak and the 8.4 benefits from girdles primarily.
    Since you won't believe my word..Brian knows his stuff
    http://www.pirate4x4.com/forum/toyota-truck-4runner/228681-myth-settled-8-4-v6-4cyl-all-8-a.html
  12. Jun 18, 2014 at 3:32 PM
    smmarine
    Melbourne FL
    If you think a Prius looks better then a taco you need help
  13. Jun 18, 2014 at 3:35 PM
    smmarine
    Melbourne FL
    :duel:
  14. Jun 18, 2014 at 5:38 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I don't believe your word because I got chance to hold both rings in my hands and thickness Is not the same. You posted link to post from 2004. How does that apply to 3.73 gears sold in 2005?
    Don't believe ? go on junkyard get both check yourself. Put two 3.73 rings on the table side by side and look. Standard one is thicker.
    Thats why Trd is splitting for people. It splits over where bolts are. If it was only about girdles like you wrote it would destroy theeths not split.
  15. Jun 18, 2014 at 5:39 PM
    #35
    awsumdc
    awsumdc Well-Known Member
    O.C. Cali
    SASED '05 Taco
    SAS, crawler box, 14" coilover shocks, 39.5 tires,dual batteries, and a bunch of other stuff
    No it's not. It's actually pretty simple to blow up one of those rear diffs. they're not that strong.
  16. Jun 18, 2014 at 5:45 PM
    #36
    BlueT
    NorthEast
    I don't think Toyota had much choice here. There are only two elockers in Toyota fleet. 8 inch and 9.5 inch used on heavy duty trucks, army and farm equipment. thanks to new standards elocker is going away in cars so there was no point of redesigning it.
  17. Jun 18, 2014 at 8:21 PM
    #37
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    The T100/Tacoma/Tundra 8.4" diff has been largely unchanged since 1993 when the T100 came out. Yukon sells one gearset for all Tacoma's 1995-2013 so I would call information from 2004 still pertinent....
  18. Jun 18, 2014 at 8:31 PM
    #38
    smmarine
    Melbourne FL
    They're pretty darn strong. I've seen 8.4s romped pretty hard
  19. Jun 19, 2014 at 7:37 AM
    #39
    BlueT
    NorthEast
    I meant ring and pinion.
    Agree on swapping whole third possibility, since it had been done before.
    I think for smaller truck elocker worked fine especially id somebody is running 4.10s or 4.56s They should be fine. Its 3.73 that is to thin and its a problem.
    Not sure what your point, there were no 3.73 gears back in 2004 when that post was made. He also mentions no thickness. Thickness was not something anybody had looked before.
    Elocker fits in pretty much the same housing just have extra notch for the arm. So space for locking mechanism had to come from somewhere.
  20. Jun 19, 2014 at 7:38 AM
    #40
    BlueT
    NorthEast
    Agree, if they can handle supercharged trucks on 35's with stock gears, they can not be that bad.
