Rear End Recall and changing fluid?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by redbird48oo, May 14, 2017.
  1. May 15, 2017 at 12:48 AM
    #41
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    What do you mean?
  2. May 15, 2017 at 5:09 AM
    #42
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    It's not "required", it is a one-size fits all recommendation that eeks out some tiny bit of mpg (letting Toyota better meet the CAFE requirements) at the expense of engine wear. It is adequate engine lubricant for average use in average North American climates, for new/lower mileage engines that really only have to make it through the warranty period.
    If you are not an average driver or live in a non-average climate, or want optimal engine protection 'cause you plan on driving the truck 'til the wheels fall off--and then putting the wheels back on and driving some more--then use an optimal motor oil for your driving and more importantly your climate's conditions.
    One other factor is engine "age", hours of operation, "miles". Older engines are "looser" than new engines--that is an inescapable fact. As they age what was once an acceptable but not optimal lubricant becomes far less optimal and less/not acceptable. That is why my '09 4.0 will be getting 10W-30 in its belly next time...
    BTW, Toyota also "recommended" the grade of steel and corrosion protection for Tacoma frames that cannot withstand some environments, the design of the rear springs that come undone and rupture the fuel tank, the design and selection of materials for the melting headlamp housings, the assembly/sealing of rear differentials, etc...
    Since those all worked out so well I guess it does make sense to blindly follow their lubricant specs...
    CrashFix likes this.
  3. May 15, 2017 at 6:28 AM
    #43
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I get what you are saying but you are going way off topic, the OP was concerned about his warranty being void for using a different brand oil. My concern is using a different spec oil can come back to bite him. Once beyond warranty then you can start using whatever you like. Toyota did step up to the plate and replace frames and springs for their mistake. If you choose to ignore the big 0w-20 sticker only under the hood then you are taking the risk of your warranty not covering any engine damage.
    EB Group likes this.
  4. May 15, 2017 at 8:55 PM
    #44
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    shakerhood likes this.
  5. May 16, 2017 at 1:38 AM
    #45
    Plain Jane Taco
    USA
  6. May 16, 2017 at 4:32 AM
    #46
    EB Group
    Rudy
    Halifax
    Sorry bro, but I couldn't disagree with you more.
  7. May 16, 2017 at 4:37 AM
    #47
    Plain Jane Taco
    USA
    Just saying....under normal conditions Toyota doesn't even show a fluid replacement....at least through the 1st 60k miles. I've not really look at the maintenance schedule beyond that.
    That said. I'm at just over 30k. I'll be swapping it out for some M1 juice soon. :thumbsup:
    EB Group[QUOTED] likes this.
