Rear end ride quality after lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by speedracer4, Oct 2, 2019.
  1. Oct 2, 2019 at 6:52 AM
    speedracer4
    speedracer4 [OP] Well-Known Member
    Troy
    Indiana
    2019 TRD Off Road Tacoma and 4Runner
    Can you explain the physics as to how/why this would happen? genuinely curious
    TrailRayted likes this.
  2. Oct 2, 2019 at 6:54 AM
    TrailRayted
    TrailRayted Well-Known Member
    Ray
    2008 Rugged Trail Tacoma
    Fair enough. I run 1" blocks in the rear. Before I installed them I researched it. The ujoints are more than capable of handling this small amount of missalignment. What are you basing this on? If you have solid proof I may just take mine out.
  3. Oct 2, 2019 at 6:58 AM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    No solid proof. Just my own personal experience. Bought the truck and it had a 1 inch block. Constant vibrations. My plan was to swap the suspension out anyway. But for shits and giggles. I removed the block and drove around. Instantly the vibes were gone.
  4. Oct 2, 2019 at 7:00 AM
    TrailRayted
    Ray
    Sorry then. You are a block hater. One of these guys that spent to much to achieve what blocks do.
  5. Oct 2, 2019 at 7:06 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    For pavement imperfections, tires make the biggest difference. What pressures are you running?
  6. Oct 2, 2019 at 7:06 AM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Wrong forum. You're in the land of block haters :rofl:
    TenderTacoNipples and NYCTaco52 like this.
  7. Oct 2, 2019 at 7:07 AM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Didnt know there was such a thing :burp:
  8. Oct 2, 2019 at 7:09 AM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Let's be real, the ONLY purpose blocks serve is lift. No performance, not flex, not increased ride quality, not strength.
    So if me wanting some actual increased capability and performance out of lifting my rear end. Then block hate all day :notsure:
  9. Oct 2, 2019 at 7:10 AM
    tcjacado
    tcjacado Well-Known Member
    Did you get the 5100's for the 1.5 to 3 inch lift or just the ones for 0 to 1.5 inch lift
  10. Oct 2, 2019 at 7:11 AM
    Mad Mark
    Mad Mark Well-Known Member
    18 TRD 4x4 off-road
    You gotta get the the higher quality 700lb rate block. Those ride the best with 5100’s
    NYCTaco52 likes this.
  11. Oct 2, 2019 at 7:12 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    OME aren’t the only ones that make rear leaf packs, you have Alcan, AllPro, Deaver, Icon etc
    That said you probably want to look into a different set of shocks. Is the ride too stiff or soft?
  12. Oct 2, 2019 at 7:14 AM
    speedracer4
    Troy
    Indiana
    standard length per vendor recommendation, said I wouldn't need the extended until I was 2.5"+
    tcjacado[QUOTED] likes this.
  13. Oct 2, 2019 at 7:15 AM
    speedracer4
    Troy
    Indiana
    lol, it's a block of steel
    tcjacado likes this.
  14. Oct 2, 2019 at 7:16 AM
    tcjacado
    Take the cb spacer out and see if that helps smooth it out.
  15. Oct 2, 2019 at 7:18 AM
    #35
    TrailRayted
    Ray
    You said it.
    You said it. They certainly don't increase off road performance. They do allow for larger tires
    I guess I can't disagree with this. If off-road use is your primary concern then yes. If lifting your truck affordably like $40 is your concern and not negatively affecting your road ride then the blocks certainly makes sense. Put a little hate in your day
  16. Oct 2, 2019 at 7:19 AM
    #36
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Try lowering the rear tire pressure.
  17. Oct 2, 2019 at 7:26 AM
    #37
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    5100s are stiff.
    na8rboy and TrailRayted like this.
  18. Oct 2, 2019 at 7:33 AM
    #38
    TrailRayted
    Ray
    They sure are. They will bring out the rattles in your ride. Maybe cause more. But I like them. Lol
  19. Oct 2, 2019 at 7:34 AM
    #39
    speedracer4
    Troy
    Indiana
    Can more people with a rear lift of 1.5"-2" and feel their ride is similar to stock share what parts you're running please?
  20. Oct 2, 2019 at 7:37 AM
    #40
    stevotivo12
    Stephen
    Front: TC Heimed UCAS, Fox 2.5 DSC coilovers
    Rear: Archive garage Hammer Hangers, SUA conversion, Deaver expo SUA leaf pack, Fox 3"x3-tube bypass shocks.
    Ride is much better than stock, no real comparison here. More compliance over little stuff, controlled flex over big stuff, enough dampening for jumps and shit:burnrubber:
