Rear end ride quality after lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by speedracer4, Oct 2, 2019.
  1. Oct 2, 2019 at 7:38 AM
    #41
    tcjacado
    tcjacado Well-Known Member
    I had the 5100's, 1 inch block and a extra overload leaf, cb spacer. The ride was good, but the back end hopped going over large bumps. I changed the shocks to the rcd 5100's and the ride smoothed out.
    Rn I have the normal 5100's, cb spacervand extra overload leaf and the ride is fine. Took out the block.
  2. Oct 2, 2019 at 7:41 AM
    #42
    speedracer4
    speedracer4 [OP] Well-Known Member
    Troy
    Indiana
    2019 TRD Off Road Tacoma and 4Runner
    What leaf did you use and how much did it lift? Seems like an extra leaf would add stiffness as opposed to a block.
  3. Oct 2, 2019 at 7:48 AM
    #43
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Fancy :thumbsup:
  4. Oct 2, 2019 at 7:49 AM
    #44
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I'm running the B110s in the rear with the Dakar Med leaf pack. Rides like shiitake mushrooms. But I also have very little weight back there and I dont mind it too much.
  5. Oct 2, 2019 at 7:50 AM
    #45
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    The block wont cause the issue like others have stated. I have one and extended 5100's. Just raises leaf but has same footprint as axle plate. 3'' longer travel shocks and running e rated 33's. My truck rides smooth. No hop or bounce. The factory shocks aren't long enough, on street should be. Might be topping them out on rebound though
    tcjacado and speedracer4[OP] like this.
  6. Oct 2, 2019 at 7:53 AM
    #46
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Add s
    I first had 2" block with 5160's (15 TRD pro set-up) ride was good, no diff then stock sport ride. Now have 3 leaf progressive in with overload in. Ride same as other set-up's... very happy with it.
  7. Oct 2, 2019 at 7:53 AM
    #47
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Icon rxt, icon shocks, timbren active bumps. Rides like a Denali.
    speedracer4[OP] likes this.
  8. Oct 2, 2019 at 8:14 AM
    #48
    tcjacado
    Yes the extra overload leaf added stiffness to the pack and lifted 1 inch.
  9. Oct 2, 2019 at 8:24 AM
    #49
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    Interesting since I have the same, (B110's & Medium Dakars) and my bed is also empty 97% of the time. My truck was only a month old when I swapped my entire suspension, and the improved ride quality in the rear was the most noticeable change.
  10. Oct 2, 2019 at 8:47 AM
    #50
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I think the issue was my dakars gave me almost 4 inches after install. So if I had to guess, it's running too high. No idea honestly
    jerzsubbie[QUOTED] likes this.
