Rear end shot on a 2011
Discussion in '2nd Gen. Tacomas (2005-2015)' started by magnetic11, Jan 3, 2014.
  1. Jan 3, 2014 at 10:53 PM
    magnetic11
    magnetic11 [OP] Well-Known Member
    "some nuke plant"
    11 trd sport
    Fab fours front and rear bumpers, B.A.M.F. weld on rock sliders, softopper, removed mud flaps and D-Badged everything. Icon 2.5 Extended Travel coil-overs, Total Chaos upppers, 2.0 Icon extended travel shocks with the resi's and Dekar Leaf packs.
    So I'm just wondering if I've got the 8 year warranty in my truck, will I be covered?
  2. Jan 4, 2014 at 3:50 AM
    RogerRZ
    RogerRZ Well-Known Member
    New Brunswick, Canada
    White '14 DCLB TRD Sport
    Depends on the mileage. I had the Gold warranty, it was covered at 80k-ish.
  3. Jan 4, 2014 at 3:55 AM
    oldracer
    oldracer Well-Known Member
    Platinum, Gold, WOW
  4. Jan 4, 2014 at 4:27 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    What broke? What happened? Miles? Off Road edition? Tire size? Did you re-gear? Whatyagot?
  5. Jan 4, 2014 at 4:34 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    define "shot"
  6. Jan 4, 2014 at 4:49 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    What I'm guessing here is... He want's to know IF he has/buys 8 yr warranty, will it cover a shot rear diff. Read your warranty, your the only one who knows what if say's.
    We don't have it to read.
  7. Jan 4, 2014 at 4:52 AM
    magnetic11
    "some nuke plant"
    11 trd sport
    I'm at 50 thousand miles. The truck has always been serviced by Toyota. I've got 255/75/17's. It's a TRD Sport with stock gears. When I put it in drive the truck will not move. At first I thought my transmission might be messed up but I can drive if I'm in 4hi. After looking at it for a short moment, it looks like to me that rear end is messed up. I've never done any crazy off roading or anything.
  8. Jan 4, 2014 at 5:12 AM
    na8rboy
    WI
    Well it's either or rear diff, or transfer case. What you could do to check rear diff, is jack up back and spin your wheels. Also check by turning drive shaft.
  9. Jan 4, 2014 at 5:24 AM
    magnetic11
    "some nuke plant"
    11 trd sport
    I had to put it in 4Hi, just to get it back down my friend's driveway. Do I think the transfer case is working. The only thing I'm worried about is Toyota giving me shit about my after market suspension, which is the toytec ultimate kit with Dakar Jeff packs.
  10. Jan 4, 2014 at 5:50 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Rear end should be covered under factory powertrain 5/60
    subbed to see how someone blew an 8.4 diff
  11. Jan 4, 2014 at 5:56 AM
    na8rboy
    WI
    Hard to tell until you check things out. If you want to yourself, or not. Like I said earlier jack up and check diff out.
    As for Toyota, they could give you some shit, and may could not. You did mention all service has been done by Toyota, so they know your truck, right?
  12. Jan 4, 2014 at 6:03 AM
    magnetic11
    "some nuke plant"
    11 trd sport
    My check engine light is on and my lsd malfunction light is on. I can drive in reverse, problem solved..lol they should know my truck and how it's set up. I've had it set up like this since 10 thousand miles.
  13. Jan 4, 2014 at 6:11 AM
    na8rboy
    WI
    That's good... Brakes control the LSD, so it sounds like it locking one of your rear drums, which won't let you drive forward, but in reverse. Just like E- brake would.
    Try disconnecting battery for a bit and see if clears system malfunction.
  14. Jan 4, 2014 at 6:18 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
  15. Jan 4, 2014 at 6:18 AM
    Large
    Large Red
    The lift won't void your warranty. They have to prove it made the truck in drivable.
  16. Jan 4, 2014 at 6:48 AM
    magnetic11
    "some nuke plant"
    11 trd sport
    That's pretty much all I'm worried about.
    I hate the traction control on my truck, I've always had problems with it.
  17. Jan 4, 2014 at 7:06 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Subbed for outcome
  18. Jan 4, 2014 at 9:17 AM
    magnetic11
    "some nuke plant"
    11 trd sport
    The outcome, I'm buying a Chevy...lol. Just joking. I'm hoping it's just the stupid traction control. I find it hard to believe that I would have messed the gears up.
  19. Jan 4, 2014 at 9:32 AM
    na8rboy
    WI
    NOOOOOO.... Not GM junk....lol Ford/non ecoboost, or Dodge....
    I'm betting that is your problem... Could be a simple recalibrating system.
    Good luck, let us know outcome.
  20. Jan 4, 2014 at 4:34 PM
    magnetic11
    "some nuke plant"
    11 trd sport
    Will do
