Rear end shot on a 2011
Discussion in '2nd Gen. Tacomas (2005-2015)' started by magnetic11, Jan 3, 2014.
  1. Jan 8, 2014 at 11:46 PM
    #121
    magnetic11
    magnetic11 [OP] Well-Known Member
    "some nuke plant"
    11 trd sport
    Fab fours front and rear bumpers, B.A.M.F. weld on rock sliders, softopper, removed mud flaps and D-Badged everything. Icon 2.5 Extended Travel coil-overs, Total Chaos upppers, 2.0 Icon extended travel shocks with the resi's and Dekar Leaf packs.
    As far as the strain on a part, the universal joints and the cv joints would be the first that I would think to go. I've got shims on my rear end. I'd say my truck is set up exactly like toytec would call for the ultimate lift kit to be installed on our trucks.
  2. Jan 9, 2014 at 8:31 AM
    #122
    Marcoc
    Marcoc Well-Known Member
    Connecticut
    2017 Tacoma TRD Off-Road LB
    2017 Tacoma TRD OR LB white w/tech package
    Glad they fixed the truck. My 2010 is out of warranty plus I bought it used so repairs are done by me mostly. My truck has 50k miles with about 2.5" of rear lift and besides the typical low speed shudder plague it has been good. Again glad they fixed it for you. Toyota stood behind you not the stealership, not a surprise.
  3. Jan 9, 2014 at 9:34 AM
    #123
    13TRDsport
    13TRDsport Well-Known Member
    NE PA
    13 Access cab TRD Sport
    Aero Turbine 2525XL, K&N air filter, TRD Shift knob. Bilstein 5100's w\Eibach springs.
    Glad they fixed your truck bud, They should have never given you any grief about it. Good for you for sticking to your guns!
  4. Jan 9, 2014 at 11:37 AM
    #124
    magnetic11
    "some nuke plant"
    11 trd sport
    I'll be honest, it could have been a lot worse but on hour long call to customer care and the next day the were singing to a different tune. But I'm very glad they fixed it and I'm glad to have my truck back.
  5. Jan 9, 2014 at 11:39 AM
    #125
    magnetic11
    "some nuke plant"
    11 trd sport
    So I was taking a look around my truck earlier and noticed that one of my rear socks looks busted and leaking. This is the second one. So it has made my mind up for me, I'm going with icons and I'm going to go ahead and install a set of their bump stops also.
  6. Jan 9, 2014 at 1:01 PM
    #126
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    If you have shims than there is possibility your pinion is now upwards. That means with out extra gear oil you have possibility of running those pinion bearings dry and sheering off pinion inside. It happens more often than people think. Oil level on the rear has to be high enough to lubricate those bearings, since Toyota uses baffle to hold oil there, there will be no splash in there.
    Who changed gear oil last time? I bet they did not fill it to correct level adjusted for your lift.
  7. Jan 9, 2014 at 2:17 PM
    #127
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I'll admit that it's been a long time since I was in the service business. Nor was it a Toyota dealership.
  8. Jan 9, 2014 at 4:02 PM
    #128
    magnetic11
    "some nuke plant"
    11 trd sport
    I do have shims on my rear axle and Toyota has done all the maintenance on my truck.
  9. Jan 9, 2014 at 8:40 PM
    #129
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is what he is talking about with the shims installed the Pinion Shaft may be pointing upwards and not getting the proper lubrication. You may need to increase the standard oil level to compensate for the angle.
  10. Jan 9, 2014 at 9:23 PM
    #130
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Just curious - who did the install of the Toytec lift?
  11. Jan 9, 2014 at 9:48 PM
    #131
    skiwaves8
    skiwaves8 Well-Known Member
    Pagosa Springs Colorado
    TRD
    If the dealer says the lift broke it you are screwed.
  12. Jan 10, 2014 at 5:13 AM
    #132
    BlueT
    NorthEast
    Chances are than Toyota service guy did not put correct oil level in your truck. That also means there is possibility that your new differential is under filled too. So unless you want to replace another Diff you probably need to add gear oil to it. Or atleast check level. Dealers are notorious on under filling things. So lift may not be what destroyed the axle, but it was contributing factor, along side with improper gear oil change procedure.
    x2
    I would think by now anybody who has a lift and shims knows, to make sure that gear oil level is correct.
    Even those with out a lift needs to pay attention to that, since leaf springs wear out and may change how an axle is positioned.
