Rear end sits higher than the front
Discussion in 'New Members' started by austincomstock, Feb 10, 2012.
  1. Feb 10, 2012 at 4:59 PM
    austincomstock
    austincomstock [OP] Member
    Utah
    99 trd sr5
    aero turbine muffler, deck plate mod, white gauge cluster lights with red needles, spyder hd headlights
    I just got my tacoma a few months back and i am trying to find the best way to lower the rear end. When i bought the truck it came with a 3 inch Bilstein lift in the front and the back shocks are also Bilstein. I don't think its a body lift in the rear because it doesn't have any spacers between the leaf spring and axel. I already had a leaf spring removed and the back is still higher, any ideas?
  2. Feb 10, 2012 at 5:13 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    How many leafs are there in the rear, including the overload leaf?
  3. Feb 10, 2012 at 8:32 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
  4. Feb 10, 2012 at 8:35 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Welcome to TW. And yes, how many are there? Photo of setup?
  5. Feb 11, 2012 at 1:10 PM
    austincomstock
    Utah
    99 trd sr5
    thanks for the reply! here are some pictures.
  6. Feb 11, 2012 at 1:17 PM
    austincomstock
    Utah
    99 trd sr5
  7. Feb 11, 2012 at 1:28 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    A couple of clarifications for you : Body lift = numerous blocks/grometts that mount between body & frame, & no you dont have any lift blocks on axle either, from looking at the springs, they're either after market or they've been worked some & you have no overload, you can drop another leaf & it'll put you back to a 3 leaf config. that'll lower some, see a fair amount of rust too, might want to hit it with a wire wheel on a cordless drill & wipe it down good, dry if wet & get a can of GOOD enamel like the rust-oleum epoxy enamel it takes a while to dry but well worth it if you live in a wet climate..
    Oh & welcome to TW from Lakeside,CA
  8. Feb 11, 2012 at 4:26 PM
    austincomstock
    Utah
    99 trd sr5
    thanks for the info. i plan on taking care of that asap!
  9. Feb 11, 2012 at 4:31 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    It looks to me like your springs no longer have any arch. That means they have either been overloaded, or are worn out. They should have a smile, not a neutral look(like you have), nor should they frown.
    The rear of your truck should be higher than the front. A 1" or less rake is normal. Without it, anytime you load it, the rear sags.
  10. Feb 11, 2012 at 4:33 PM
    DCW
    DCW Well-Known Member
    David
    Reno, Nevada
    2011 TRD DC Off Road
    TRD exhaust, front skidplate,5100s@1.75
    Welcome to TW from Reno, NV
  11. Feb 11, 2012 at 4:35 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    14 dudes will be lined up trying to get the springs he takes off, me included.
  12. Feb 11, 2012 at 4:37 PM
    austincomstock
    Utah
    99 trd sr5
  13. Feb 11, 2012 at 4:52 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Wow, y'all like flat springs? You can keep em. I like ones that work correctly!
  14. Feb 11, 2012 at 5:18 PM
    wolftree
    Rick
    Ohio
    Automotive springs, tie rods etc. are excellent steel for blacksmithing metal projects, making tools.
  15. Feb 11, 2012 at 5:55 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Didn't think of that. I thought there were poor TW guys with broken leaves, lol.
  16. Feb 11, 2012 at 6:32 PM
    Pugga
    Massachusetts
    The picture of your truck looks like it's a little noise high :notsure:
    Also, looks like you removed the overload leaf spring.
  17. Feb 11, 2012 at 6:36 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    X2 from that angle it looks like you should raise the rear, not lower it.
  18. Feb 11, 2012 at 6:37 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You want bro lean OP ?
  19. Feb 14, 2012 at 1:58 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
    So what does the front look like? Are they adjustable? You might want to raise the front insted of lowering the rear.
