Rear end slams hard over speed bumps with AAL
Discussion in 'Suspension' started by DNG, Feb 27, 2012.
  1. Feb 27, 2012 at 5:15 PM
    DNG
    DNG [OP] Well-Known Member
    Orange County, CA
    White 01 DC PreRunner
    If I go over speed bumps with any speed, my rear end comes down hard like I hopped a curb. Is this common of progressive AAL or should I be replacing my rear shocks?
  2. Feb 27, 2012 at 5:27 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Maybe gets some timbern bumpstops and maybe some better shocks
  3. Feb 27, 2012 at 5:29 PM
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    Mine did that when i blew the top of one of my shocks out.....I noticed it when i saw the metal rod sticking through the bottom of my composite bed
  4. Feb 27, 2012 at 5:33 PM
    VanCity4x
    VanCity4x The shit show
    DJ
    BC
    05 Prerunner SAS
    3link 1tons on 40's and sum stuff
    I have the same, im on 2'' blocks in the rear. Hitting your bump stops when going over it. Adding the lift soffens the shocks. Going to add some firmer procomp shocks on myself.
    Air bags would help if you use your truck for towing or have a lot of weight in the rear.
  5. Feb 27, 2012 at 5:39 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Did you just put the AAL on?
    Typically the progressive AAL's ride very nice and absorb speed bumps.
  6. Feb 27, 2012 at 6:11 PM
    mondexyota
    mondexyota Well-Known Member
    Beau
    Titusville, FL
    2010 Barcelona Red DC SR5 4x4
    3" Toytec spacer lift, 285x70x17 Nitto Terra Grapplers on 17x9 XD Misfits
    I had this problem also. I just installed a set of Bilstien 5100 rear shocks, problem solved! I am now getting ready to redo my front suspension setup with some aftermarket coilovers & upper crontrol arms, then I will be able to hit speed bumps as fast as I want! LOL
    Bilstiens 5100's here...https://www.allprooffroad.com/05tacomarearsuspension/507
  7. Feb 27, 2012 at 6:16 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    Was this happening before you put the springs on?
    Blocks are not the same as springs, and yes you would bottom out pretty hard with 2 inch lift blocks.
  8. Feb 27, 2012 at 6:26 PM
    DNG
    Orange County, CA
    No, I've had them on for about 20k miles.
    IIRC, it wasn't as stiff with the stock leafs.
    I thinking my shocks are worn out. Just wanted to see if anyone had the same problems
  9. Feb 27, 2012 at 6:27 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    So I take it you didn't upgrade to a longer shock when you put the AAL in correct?
  10. Feb 27, 2012 at 7:52 PM
    DNG
    Orange County, CA
    No. I'm looking at the billy 5125s now. Good option?
  11. Feb 27, 2012 at 8:32 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    I am not familiar with first gen suspension but as far as I have heard yeah that is a good option. Ask some of the 1st gen guys they will steer you in the right direction :thumbsup:
    EDIT: You can always call DSM. Tell them what you are running and they will be able to hook you up. Plus you get a TW member discount.
