Rear end squats with load
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zdog, Aug 14, 2011.
  1. Aug 14, 2011 at 9:19 PM
    zdog
    zdog [OP] Well-Known Member
    Oregon
    2010 5lug Access Cab SR5 2.7/5speed
    I really like my 2010 Tacoma but when I haul any kind of load that is more than a couple of hundred pounds the rear end starts to squat. I don't haul very often but I would like to increase my load capacity without the rear end hunkering down. Is there an unobtrusive way to stop that happening that doesn't involve re-springing the whole rear end? Does the TSB cover this year and model Tacoma?
    Thanks,
    zdog
  2. Aug 14, 2011 at 9:24 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    It's going to squat as you add weight...You can install an AAL, but that will lift the rear slightly when not loaded.
  3. Aug 14, 2011 at 9:25 PM
    Darth Tater
    Darth Tater If I can't get you out, neither can anyone else.
    Marlin
    Las Vegas, Nevada!!
    06 4X4 Taco, ARB, DBL Cab
    ARB,WARN 8K (F&R), 3" lift, Snugtop, tube steps, factory roof rack, Dick Cepeks,
    Your should be new enough, you should be able.to get the tsb done. Your other options are some helper springs, or an aal. I have a set of helwig helpers that I run when I haul my quad. Tighten them up when I need them, loosen them when I dont. Check ebay, or Amazon. toyotec carries a set of airbags, but it is a.firestone kit and about $300. Just my $0.02
  4. Aug 14, 2011 at 9:27 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Yeah, the "Harsh Ride" TSB. They will replace your current leaf pack with a better one that will be stiffer and will cause your rear to sit up a little higher (roughly an 1" higher) Seeing your truck is an 2010 it should be under warranty. Go to your local dealer and address this problem to them, tell them you are having a horrible ride in the rear and tell them it squats with A load. It just all depends which Dealership you go to, I've seen people on here get denied the TSB work. I got lucky and had no problems getting it done...
  5. Aug 14, 2011 at 9:36 PM
    lightmup
    lightmup Well-Known Member
    Utah
    07 db cab TRD sport 6" fabtec lift 33-13.5-20
    AFE intake, Gibson cat back exhaust, Fabtec 6"lift, King remote resy coilovers, Light Racing UCA's , Allpro front bumper,PIAA fogs, 3 KC slim lights, Optima battery, Weathertech flour mats, Tinted windows, Wheels and tires, Back up camera, 10" shallow mount kenwood sub
    Does it look something like this? It can handle the load it just looks like its draging ass when it dose it.:D
  6. Aug 14, 2011 at 9:37 PM
    krimson
    krimson Nothin
    TRD Off Road
    Damn that's a nice boat!
  7. Aug 14, 2011 at 9:45 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    I put air bags on my 04. Didn't have to mess around with the leafs and the ride stays the same. I just add or release air depending on the load.
  8. Aug 14, 2011 at 9:49 PM
    lightmup
    Utah
    Thanks man! We love it.
  9. Aug 14, 2011 at 10:00 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    TSB kinda helps though.
    I brought my dads 2010 TRD OR in, and they did the tsb no problem. Search the site for the PDF file and bring a printed copy with you. The 2wds get replaced bump stops as well IIRC.
  10. Aug 14, 2011 at 10:14 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    The TSB springs suck , I had them from the factory
  11. Aug 15, 2011 at 6:01 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    If you are going to be consistently carrying loads above 500 lbs then I would recomend going with airbags. Of course it won't hurt to get the "harsh ride" TSB completed if you are still under warranty. It's not a fix all but it will help.
  12. Aug 15, 2011 at 6:11 AM
    acdronin
    acdronin Well-Known Member
    I just installed the firestone Riderite air bags and I love em, my loads vary but I have a cap and rack on mine so there is always weight on my rears. I've put on 2 inch aal's and rear Bilstein 5100's as well so my load capacity is much higher now than before but, the air bags are there specifically to prevent the rears from squatting under loads.
  13. Aug 15, 2011 at 6:17 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    x2.
    After 4-5 years they sag like shit. My front is actually a bit higher than my back giving me a lil bit of bro lean that I really don't like.
    Dakars soon. I'm just concerned about bleeding the brakes when installing the extended brake lines.
  14. Aug 15, 2011 at 6:24 AM
    acdronin
    X2 The only things I don't like on these trucks are the rear leafs and the brakes
  15. Aug 15, 2011 at 6:25 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    And the disposable wheel bearings, and the shitty-from-factory front diff bearings.
    Edit-Not sure the exact weight of all this lumber but I was sitting an inch off the bumpstop.
  16. Aug 15, 2011 at 7:14 AM
    OZ-T
    Peter North
    British Columbia
    You don't need extended brake lines with the Daks
  17. Aug 15, 2011 at 7:18 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Bleeding the brakes isn't too hard. JLee did a write up where he used a pneumatic bleeder (not necessary but makes the process very simple).
  18. Aug 15, 2011 at 9:04 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I thought to get full flex out of them you do?
    I might have to have a look at that. Thanks for the heads up. Reppified.
  19. Aug 15, 2011 at 9:22 AM
    OZ-T
    Peter North
    British Columbia
    Maybe if you are doing crazy flex , I experimented with my truck and flexed the rear so the passenger side was stuffed and the driver's side at a pretty good droop and had a couple inches of slack still
  20. Aug 15, 2011 at 9:25 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Good to know.
    BTW - Your guys gas prices are fucking ridiculous. 1.28 for regular? We're at 1.11 here.
