Rear end squeak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by harshest, Jun 16, 2009.
  1. Jun 16, 2009 at 2:56 PM
    harshest
    harshest [OP] I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    I have an 05 PreRunner Sport with LSD and just lately I have noticed a very rapid squeak coming from the back of the truck. I only does this at low speeds (under 20mph) and only under acceleration at low speeds. I will check the rear diff level tonight but after that I am out of ideas. I did change the rear diff fluid about 6,000 miles ago
    Anyone else have any ideas?
  2. Jun 16, 2009 at 2:58 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    Did you put LSD additive in the rear end as well?
    Also have a look at your hangar bearing (if the prerunner has one...). My S10 did the same thing it lower speeds.
  3. Jun 16, 2009 at 3:05 PM
    harshest
    Michigan
    05 PreRunner SR5
    Yep did include the additive, bought it from the dealer. What/where is the hanger bearing?
  4. Jun 16, 2009 at 3:28 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    U-joints?
    Take a look at your driveshaft thoroughly.... your gas tank shielding could be bent like mine was.
    Also ttyler is referring to the carrier bearing on the driveshaft I believe. Its halfway down the driveshaft.
  5. Jun 16, 2009 at 3:28 PM
    ttylerr
    Tyler
    09 MGM 4Banger 4x4
  6. Jun 16, 2009 at 4:22 PM
    harshest
    Michigan
    05 PreRunner SR5
    Thanks I'll check it out.
  7. Jun 25, 2009 at 6:10 AM
    harshest
    Michigan
    05 PreRunner SR5
    Alright so I crawled under the truck a few nights ago to lube everything up only to find no grease fittings anywhere on the drive line. I checked all sides of all the U joints. Where it connects to the transmission, the rear diff and at the carrier bearing. What gives?
    Also I was able to recreate the squeak by pushing up on the drive shaft. The squeak is coming from the rear springs which tells me the drive shaft has some pretty good vibrations going on for it to move up and down so much that is causing the rear springs to squeak.
    The rear springs squeak when I lift up on the back bumper but not when I push down. I got some silicone lube and soaked all of the moving part of the springs but it still squeaks. I think I may have to take them apart and grease them up.
    Is there anything I can do to correct the drive shaft vibration short of buying a new Tom Woods shaft?
  8. Jun 25, 2009 at 6:38 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    If your drive shaft were vibrating you would feel it in the cab. It sounds more like the leafs are "dirty" inbetween each spring. Don't worry about your drive shaft. You can try spraying some penetrant type oil inbetween each spring and see if it reduces/eliminates the squeak. You aren't the first person to have this problem.
  9. Jun 25, 2009 at 7:07 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    Use a screwdriver to wedge between the leafs and pry the leafs appart so that the silicone spray will cover the pads between each leaf.
  10. Jun 25, 2009 at 7:38 AM
    harshest
    Michigan
    05 PreRunner SR5
    I can feel it in the cab. I feel it under throttle pressure, then it eases slightly when I take my foot off the gas.
  11. Jun 25, 2009 at 7:40 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    That sounds like a bad u-joint. When you checked the drive shaft did you find any play in it?
  12. Jun 25, 2009 at 7:49 AM
    harshest
    Michigan
    05 PreRunner SR5
    Nope
  13. Jun 25, 2009 at 8:02 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    It could be your carrier bearing then.
  14. Jun 25, 2009 at 8:15 AM
    harshest
    Michigan
    05 PreRunner SR5
    That is kind of what I was thinking but don't really know how to verify that.
  15. Jun 25, 2009 at 8:19 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    As I recall, the carrier bearring has a little bit of play naturally. Let me see if I can get one of the other guys over here with a little more experience on them.
  16. Jun 25, 2009 at 8:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The CB does have a bit of play. Get under the truck, and push up on the center of the drive shaft....it should only move at the CB about 3/4" max. Does this sqeak increase or decrease with speed?
  17. Jun 25, 2009 at 8:48 AM
    harshest
    Michigan
    05 PreRunner SR5
    Yes, it increases with speed and then goes away at about 30 mph.
  18. Jun 25, 2009 at 8:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would check for something rubbing on the drive shaft....Maybe a heat shield or something.....
  19. Jun 25, 2009 at 9:00 AM
    harshest
    Michigan
    05 PreRunner SR5
    I have done that, i put the rear end up on jacks and spun the shaft and didn't hear the squeak. But when I pushed up on the drive shaft at the carrier bearing with the rear end on jacks I head the squeak from the springs.
    That is what leads me to believe that maybe axle wrap is causing the drive shaft to vibrate similar to this.
    I have been thinking of a rear AAL and maybe this is the perfect time since I may take the leaf spring apart to lube it up. That should also help with axle wrap right?
  20. Jun 25, 2009 at 9:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok then...The squeak is comming from the springs, you can take it to a car wash and sray the springs really good. There could be dirt in them causeing the noise. If this doesnt work, let me know.
