Rear End Support for Weight.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cctk2, Apr 8, 2016.
  1. Apr 9, 2016 at 12:50 AM
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    Has anyone used these Sumosprings off road? Do they limit travel?
    On longer trips with a bed-load of stuff and a shell, I sag in back enough to make the headlights aim high. These might work well for my needs if they don't adversely affect off-road ability.
  2. Apr 9, 2016 at 6:36 AM
    cctk2
    cctk2 [OP] GLACIERBIRD
    Chip
    NorCal and Alaska
    '68 FJ40, '16 TRD AC OR A/T WHITE
    Accessories: SnugTop Rebel canopy AVS Window Rain Deflectors TACOMA 6' Bed Mat Weathertech Mud Guards (4) Scanguage (re-installed from the '02) Tekonsha Voyager Brake controller (Chalet A frame pop-up.) Vinyl letter insets for tailgate. Garmin CS60 GPS mounting. Other misc décor in the form of decals.
    Some variants of sumos, like airbags, attach both at bottom and top limiting travel.
    The SSR 610 40s for the Tacoma attach at the bottom only. Lack of attachment at the frame allows unlimited travel. Therefore the axle drop is unlimited.
    With compression, 80% is what they claim. That is possibly greater travel than the OEM bump stops.
    Note: For some of the variants of Sumosprings which do attach at both ends, yet another variant has been developed which is two piece. One attaches at the axle, the other at the frame. But being two piece, they separate, and by design auto-realign at compression. Again though, the Tacoma is a single point attachment at the axle.
    HalfWayThere likes this.
  3. Apr 9, 2016 at 7:00 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Pics looked the same to me
  4. Apr 9, 2016 at 9:59 AM
    cctk2
    Chip
    NorCal and Alaska
    There are dozens of model kits depending on the vehicle. When I researched this, I finally called the company, contacted eTrailer, as well as other suppliers.
    Advertising sometimes is less than desirable with MANY things. Anyone thinking about ANY mod, accessories, etc. should be served by doing some research and knowing what is needed as well as what the results MIGHT produce.
  5. Apr 13, 2016 at 10:59 PM
    cctk2
    Chip
    NorCal and Alaska
    With the Sumos on, and the truck empty:
    1) The rear of the truck was lifted approximately 5/8". (Measured to the inside of the fender well centerline at the axle.)
    2) Ride MIGHT me slightly stiffer? Possibly only imagination.
    To date, still happy with the decision to install them, especially with the trailer on board.
    3dBdown[QUOTED] likes this.
  6. Apr 14, 2016 at 5:56 AM
    Inferno_Taco
    Inferno_Taco Well-Known Member
    2015 TRD Pro
    @cctk2 thanks for taking the time to review these for us.
    I have a set of these arriving today. Hoping to get them installed over the weekend. Will report back my experience with them.
    cctk2[OP] likes this.
  7. Apr 14, 2016 at 11:57 AM
    tacomajoe16
    tacomajoe16 Active Member
    Joseph
    Deland FL
    2016 Tacoma TRD Off-Road DCSB White
    Tailgate letters, Bed matte, Mud guards, Exhaust tip, LED cube flood lights
    Hey Glacierbird, great info, Was the kit you used part #SSR-610-40 from Amazon?
    cctk2[QUOTED][OP] likes this.
  8. Apr 14, 2016 at 12:23 PM
    Inferno_Taco
    2015 TRD Pro
  9. Apr 14, 2016 at 1:50 PM
    cctk2
    Chip
    NorCal and Alaska
    That is the correct part. I think you'll be surprised how easy they install, and will be pleased with the result.
  10. Apr 14, 2016 at 10:29 PM
    justintackitt
    justintackitt Well-Known Member
    2016 Tacoma DCTRD4X4
    I have the timbren SES set up. Works great. I tow a 4900 lb concession trailer. I also use a weight distribution hitch that helps eliminate rear end sag too.
  11. Apr 15, 2016 at 6:06 AM
    Danielnc06
    Danielnc06 Well-Known Member
    NC
    2016 TRD DCLB
    OP,
    Do you have the tow package? I'm just curious if that fourth leaf spring in the tow package really does any good if a 260lb tongue weight sags it so much.
  12. Apr 15, 2016 at 6:43 AM
    cctk2
    Chip
    NorCal and Alaska
    I do have the tow pkg.
  13. Apr 15, 2016 at 8:53 AM
    ArnieSea
    ArnieSea Well-Known Member
    Arnie
    Salish Sea, WA
    2016 Double Cab TRD Sport 4X4
    Blazing Blue, with full tech package, Tow Package, & Tonneau cover.
    I have had the EXACT same experience! My trailer is an Aliner Classic, (A-Frame pop-up like yours) with similar GVW & tongue weight. I had a 2014 SR5 with tow package and Firestone air bags. It worked great. No issues except the hassle of adjusting the air per load. I did find that the 5lbs of minimum air did stiffen the ride while empty.
    Now I have a 2016 DBCB Sport. I choose this model specificity for the ride on the highway. I'm not a rock crawler so don't need the OR features. I have been reluctant to go back to the air bags for fear of messing with the ride. I have looked at WD hitch options, but with trailers as light as ours, we really don't need them. The Tacos pull them just fine. (I also have the Prodigy 3 controller.)
    So thank you! I ordered Sumo Springs this morning from Amazon. Looking forward to the install. One question: do the instructions tell you how much torque is required? You mentioned buying a torque wrench but I did not see the tightening specs.
    Next I need to find some nice tow mirrors. I had the A1 Ram flip-up mirrors on my 2014 and loved them. But they don't offer a model that supports the blind spot monitoring....yet.
  14. Apr 15, 2016 at 9:38 AM
    cctk2
    Chip
    NorCal and Alaska
    The SSR 610 40 kit includes complete instructions, torque values too. And its high; like 97ftlbs or so. That's probably why they say to put the brackets on, torque them, then drive a couple hundred miles. Then re-torque and final the project. Pretty simple.
    I had mirror extenders for my 02 Tacoma towing my Chalet. But find the new width of the '16 ample to see down the sides on the Chalet. Wont miss the hassle of attaching the extenders every trip.
    ArnieSea likes this.
  15. Apr 15, 2016 at 2:03 PM
    #35
    ArnieSea
    Arnie
    Salish Sea, WA
    The Chalet and Aliner are both 78" wide but I still like a few extra inches on my mirrors. I have CIPA clip-on at the moment, but agree they are a hassle. Also I prefer flat over convex on both sides for backing up. It is easier to judge where by trailer wheels are. My driveway curves uphill so getting my trailer parked just right is a challenge with convex mirrors.
    Thank again for the Sumo write up and all the info. Looking forward to getting mine installed.
  16. Apr 16, 2016 at 1:06 PM
    #36
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
    I took your advice and installed the SumoSprings 610-40 on my Tacoma and it has made a big difference when towing or when I load up a lot of mulch from Home Desparate in the bed.
  17. Apr 16, 2016 at 5:12 PM
    #37
    Azbadboyz
    Azbadboyz Well-Known Member
    2/2016 Tacoma's one bright white 2nd inferno
    I had the Firestone air bags on my 2011 Tacoma and had the onboard compressor with gauges so I could regulate them. I think it is the only way to roll. I could adjust for different loads.
  18. Apr 16, 2016 at 5:58 PM
    #38
    The OR LB 16
    The OR LB 16 Well-Known Member
    Tom
    Tacoma 2016 TDR Off road LB
    Great thread . I am sold and want these also.
  19. Apr 16, 2016 at 6:11 PM
    #39
    Inferno_Taco
    2015 TRD Pro
    Just put a set on my Taco. So far they are great! Easy to install, no affect on unloaded ride quality and provide some load handling.
  20. Apr 16, 2016 at 6:28 PM
    #40
    The OR LB 16
    Tom
    Thanks for the picture .
