Rear End Swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by BoostingMS6, Mar 13, 2011.
  1. Mar 13, 2011 at 8:28 PM
    BoostingMS6
    BoostingMS6 [OP] Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    I am sure this has been covered, but my search did not find any conclusive results -- so please do not tell me to use the search. If you would like to link any previously discussed topics, that would be appreciated though!
    I have a '95.5 Xtracab V6 4x4. I want a rear locker. Someone in my local area is selling the entire rear axle from a 2003 TRD Tacoma. General question: Will it fit? If not, why not?
    I fully realize I need to do more research on this topic. But its very hard to find the rear end of a TRD in my location. I'd like to not pass it up if it works. Any answers would be greatly appreciated!!
  2. Mar 13, 2011 at 9:10 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Yes it will fit, are you sure it is the correct axle with the e-locker? Sometimes they advertise it's from an TRD.. but they lie/don't know.
    How much you paying for this?
  3. Mar 13, 2011 at 9:11 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Outer Space
    It will fit. Does it come with the wiring harness, ECU, and diff lock button?
    EDIT: I did a rear axle swap on my tacoma. You need to make sure that axle has the right gears. I believe it's 4.10 gears which is stock. How much do they want for the axle?
  4. Mar 13, 2011 at 9:54 PM
    BoostingMS6
    Alex
    El Paso, TX
    The axle has 38,000 miles on it. They are asking $800, but its on Craigslist, so I'll argue it down. What's the maximum you would pay for it?
    Does my truck stock have the 4.10's?
  5. Mar 14, 2011 at 12:32 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Dude, if it is as you say, don't spend alot of time arguing about price, $800 is a bargain, jump on it, These are usually around $1100-$1200 when you can find them....
  6. Mar 14, 2011 at 12:43 AM
    BoostingMS6
    Alex
    El Paso, TX
    Oops, my post above yours need edited. It was supposed to say ask if the 2003 Prerunner TRD would have 4.10's?
    I'll give the guy a call tomorrow morning and see if I can't stop by to look at it.
  7. Mar 14, 2011 at 1:03 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    As far as gear ratio I'm not sure but usually lower ratios (4.10's, 4.88's etc:) are for manual trans & higher ratios (3.80's, 3.73 , etc;) are for automatics
  8. Mar 14, 2011 at 7:03 AM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    I still had 4.10's in my auto, and I beleive some even came with 4.56's.
    OP, get the VIN off the vehicle, we can tell you what gear ratio it had.
  9. Mar 14, 2011 at 7:11 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yeah, leave it to Toyota to be different I guess
  10. Mar 14, 2011 at 4:02 PM
    BoostingMS6
    Alex
    El Paso, TX
    His A/TM code is BO3A/A340E. That's all you guys need, right?
    Let me know if you ACTUALLY need his VIN. I can get it tonight.
  11. Mar 15, 2011 at 10:34 AM
    BoostingMS6
    Alex
    El Paso, TX
  12. Mar 16, 2011 at 11:14 AM
    BoostingMS6
    Alex
    El Paso, TX
  13. Mar 23, 2011 at 8:59 PM
    Mcgruber96
    Mcgruber96 New Member
    sjlucero74@gmail.com
    Wicked valve stem covers, stickers and decals that add 10 HP each!
    Hello, any luck on that rear end? I have a 96 taco and want to do the same thing.
  14. Mar 24, 2011 at 5:15 PM
    BoostingMS6
    Alex
    El Paso, TX
