Rear end swaps
Discussion in '1st Gen. Tacomas (1995-2004)' started by ubermx5, Oct 7, 2008.
  1. Oct 7, 2008 at 3:52 PM
    ubermx5
    ubermx5 [OP] Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    What years Taco will swap with no issues?
    I was wondering if I could get 4X4 rear end for me 4X2.
    So it would have a LSD..
    I have a 1998..
  2. Oct 7, 2008 at 5:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I dont think the 4x4's or PreRunner's will swap right out and into your truck. The axels are a little wider, and they are made for a spring over axel mounting, as yours is a spring under axel mounting. It could be done, But, unless you have a sawzall and a welder, just buy an LS for your axel. You have a 7.5" rear. :)
  3. Oct 8, 2008 at 4:12 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Chris is right...
    Not only all that - but you have a different lug pattern. Look on your wheels - you have 5 lugs. The 4X4 has 6 lugs.
    You're much better off doing some research to find an aftermarket LSD for your truck.
  4. Oct 8, 2008 at 5:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL. I have been around TTORA so long, I have gotten used to seeing trucks with 6 lugs in the rear and 8 on the front, I forget to even think about them anymore. :eek:
