Rear end trouble... now what
Discussion in '1st Gen. Tacomas (1995-2004)' started by Freediver, Jan 23, 2017.
  1. Jan 23, 2017 at 1:06 PM
    Freediver
    Freediver [OP] New Member
    1997 Tacoma 4wd
    97 Tacoma 4wd, locking diff, ABS... rear axle seal went out, now mechanic is saying axle is stuck and prob be cheaper to find a used rear end, swap the whole thing out.
    Thoughts appreciated
  2. Jan 23, 2017 at 1:10 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Axle seal failed and you lost fluid to the point it damaged the differential?
  3. Jan 23, 2017 at 1:11 PM
    Freediver
    1997 Tacoma 4wd
    Appears to be the case
  4. Jan 23, 2017 at 1:28 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Only thing that should be holding axle in is the 4 nuts on back of drum. Nothing inside diff keeps it in place. For it to possibly bind up tight on it there would have to a major malfunction in diff and youd definitely know it...
    Freediver[OP] likes this.
  5. Jan 23, 2017 at 1:32 PM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Tell Mechanic to show you what's wrong sounds like he's trying to get more money out of you
    Freediver[QUOTED][OP] likes this.
  6. Jan 23, 2017 at 1:39 PM
    Freediver
    1997 Tacoma 4wd
    He's saying its "hung up in the housing"...
  7. Jan 23, 2017 at 1:41 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    I still think you need to go into his shop have him pull all parts apart and show you what's wrong. A good Mechanic would a bad Mechanic would tell you to get fucked should be able to figure that out pretty easily
  8. Jan 23, 2017 at 1:42 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Usually the only thing to worry about is the wheel bearing going bad from the diff fluid entering the blown seal and washing away the grease inside of it. How long has it been since your truck was last inspected by a mechanic or yourself?
  9. Jan 23, 2017 at 1:45 PM
    devinzz1
    devin
    2023 aclb trd or mt
    I hope hes not trying to remove the third member...
  10. Jan 23, 2017 at 1:45 PM
    Freediver
    1997 Tacoma 4wd
    Everything was just checked out, fluid etc, at the end of a 3 hr drive got out and saw oil poring out of axle seal, took it straight to mech and here we are
  11. Jan 23, 2017 at 2:05 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    May have killed your wheel bearing but idk if your axle is seized.
