Rear end upgrades on a 2010 X-Runner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hacktacular, Jan 2, 2018.
  1. Jan 2, 2018 at 3:19 PM
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    Debating whether to change the entire rear end or swap it for something else which has LSD/posi or upgrade diff and do disk conversion. Has anyone done a swap and which rear would be best?
    Also, what gear ratios are best for our trucks? Will a 4:10 be better than stock?
    TIA
  2. Jan 2, 2018 at 7:15 PM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    Ford 9”
  3. Jan 3, 2018 at 5:15 AM
    Hacktacular
    Robert
    Well that's probably not an easy bolt in at all. I was thinking more along the lines of a Toyota rear with a disk brake setup. 4runner, Tundra, etc?
  4. Jan 3, 2018 at 6:09 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    4Runner can, but you'll need to add in leaf spring perches.
    Hacktacular[OP] likes this.
  5. Jan 3, 2018 at 6:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You'd still need to add in the LSD of choice.
    One thing to remember, is that for the X-Runner, some people would swap in a PreRunner third member with the 3.73 ratio, as an "upgrade." It generally didn't last long back there because the rpms were always so high. A 3.30 would be a likely better choice, since yours starts as a 3.15:1.
  6. Jan 3, 2018 at 8:08 AM
    Hacktacular
    Robert
    Right, looking at almost a grand to do different and then disk brakes would be another bundle of cash. Just wondering if it would be easier to swap it and make it stronger at the same time...
  7. Jan 3, 2018 at 8:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Depends on how cheaply you can find that axle, and then the labor to have it modified to fit your truck.....
    Does said axle come with brakes attached already?
  8. Jan 3, 2018 at 8:50 AM
    Hacktacular
    Robert
    No idea. Just tossing idea around
