Rear end vibration after replacing whole rear end
Discussion in 'Technical Chat' started by Logan22, Oct 28, 2016.
  1. Oct 28, 2016 at 8:05 PM
    Logan22
    Logan22 [OP] Well-Known Member
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    Tonneau Cover, Tube Steps, Kenwood Excelon KDC X895, Boston Acoustics Speakers, 12 Shallow Mount Rockford Fosgate punch p3s sub, Rockford Fosgate Punch 400 watt amp 18 in. xd spy's 285 60 18 terra grapplers
    I have a 2006 dcsb 4.0 auto 4x4 and it has 190,000 miles on it currently. It started having a rear end vibration a little while ago and I replaced the u joints. It helped, then they wore out again quickly, and when I took it in to get them replaced, the mechanic noticed the rear axle seal was leaking and the rear end had no diff fluid in it and had metal shavings in it. So i had the whole rear end replaced and get new u joints again....I changed out my leaf springs and put on bilstein shocks at about 150,000 miles so I wouldn't think its an axle wrap issue. It vibrates noticeably when taking off somewhat quickly from a stop..worsens the harder you take off. Also it will do it when already going and giving it gas to where it has to drop down a couple gears. The vibration worsens the heavier the load you put on it from accelerating and every once in a while it will vibrate when cruising at high speeds and low rpms. Any idea what the problem could be? I just dropped $2000 getting the new rear end and u joints and the problem only seemed to get worse.
  2. Oct 28, 2016 at 8:09 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Are your U-boats tightened down? Also do you have a lift?
  3. Oct 28, 2016 at 8:25 PM
    Logan22
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    Front bilsteins are set at .85 or whatever the first notch on the shocks were and other than that no lift and the u bolts are tightened
  4. Oct 29, 2016 at 2:31 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Drive shaft installed out of Phase ??
    Ask your mechanic if he installed the driveshaft in phase
    Driveshaft bent ?? Out of Balance ??
    You replaced the differential or got told you needed to replace the complete axle ??
  5. Oct 29, 2016 at 1:30 PM
    Logan22
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    I'll have to ask him about the driveshaft...they replaced the differential not the complete axle. The vibration actually got a little worse after they did that but it's the exact same type of vibration/shudder...I just noticed that the bolt on the gear case of the axle is now leaking oil. I also have a squeak coming from the rear end after they messed with it. It's not my brakes....any idea of what it might be? U joints look greased up. The repairs cost $2,000 total and everything is the exact same with the same problems and now I have a little continuous sqeak when when moving.
  6. Oct 29, 2016 at 1:34 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    That sucks. Find a new mechanic.
    Logan22[OP] likes this.
  7. Oct 29, 2016 at 4:01 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    That is one of those things the shop could not get it correct the first time .
    Would you want to give them another shot.
    This must have been making the vibration as soon as you drove it ??
    How long has it been ??
  8. Oct 29, 2016 at 9:46 PM
    toyodajeff
    jeff
    06 reg cab sr5
    I'd look at your carrier bearing, make sure the u bolts are torque to spec, I think it's about 105 ft pounds, but you should double check that to be sure.
