Rear end vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MattBoston, Jan 24, 2017.
  1. Jan 24, 2017 at 5:50 AM
    MattBoston
    MattBoston [OP] New Member
    2008 Tacoma DCSB TRD Sport
    I just purchased a 2008 Tacoma DCSB TRD Sport 4x4 back in December. Over the past few weeks I've started noticing a vibration coming from the back, possibly passenger side. It seems to be when I'm starting to accelerate and going anywhere from 15 to 35 mph and still accelerating. It almost feels like either the rear end is bouncing or engine is struggling. Going up hills the problem is more pronounced but it can even happen on completely flat roads. I can either slow my acceleration or really gun it and it will go away. Any ideas what this could be?
    ChadsPride likes this.
  2. Jan 24, 2017 at 5:52 AM
    techride
    techride Weekend Warrior
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Bilstein/Icon 2" suspension lift with wheelers 5 leaf springs, 7-pin relocate through bumper, bfg KO2s, redline hood struts, immryo mirror relocation, stubby antenna, dipped emblem, heated mirrors, Jason trek cap, led fogs, debadged
    Check your u-joints. My bet is one or more are in need of service or replacement.
    MattBoston[OP] and ChadsPride like this.
  3. Jan 24, 2017 at 10:21 AM
    Pigpen
    Dan
    Northwest Montana
    Replace all if doing one. Only use greaseable Spicer u joints.
    techride and MattBoston[OP] like this.
  4. Jan 30, 2017 at 5:30 AM
    MattBoston
    So based on a youtube video, I got under the truck and tried to "shake" the u-joints and they didn't seem to move. Could it be something else?
  5. Aug 30, 2020 at 10:46 AM
    ORtoCOTaco
    ORtoCOTaco Well-Known Member
    Colorado
    2018 White Tacoma TRD Off Road DCSB 4x4
    BodyArmor 4x4 HiLine Winch Bumper, Warn Zeon 10-S, Uptop Bravo Roof Rack, ExtremeLED Super Stealth 40" LED Light Bar, DV8 Offroad 20-Inch BRS Pro Series LED Light Bar, Truxedo Roll-Up Tonneau Cover, Automatic Tailgate Lock, Trailgate panel, cheap Amazon ditch lights.
    You ever figure this out? I have a 2018 and starting to get some vibration. Still at square one so researching all ideas before I start jumping in.
