Rear end weight and OEM lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mt203, Jun 1, 2021.
  1. Jun 1, 2021 at 9:17 AM
    Mt203
    Mt203 [OP] Member
    2021 Toyota Tacoma Limited
    So this is my first Taco, previously had a 2011 Tundra TRD that was fantastic but ride quality was really harsh coupled with 12mpg at best decided to take the dive and trade it for a new Taco. First thing I did was ordered a Leer 100XR truck cap color matched to the Army green of the Tacoma and then ordered a Decked drawer system. I've used or had both previously and liked them both. My question is between the two it's around 350lbs in the rear end. I like the stock height of the Taco but don't want to have it riding low or looking like I'm a dog dragging across the carpet. This is essentially the dry weight of these two as I will be adding gear back there 100-200lbs. The truck will be a bit of off road, gravel roads, and pavement. In the expert opinions here would it help or be worth it to get the TRD OEM lift? Or should I be looking a different direction?
    My main concerns are I don't want to make the ride harsh, don't want to drop back down to my Tundra fuel mileage area, but don't want to be real low.
    rizrox likes this.
  2. Jun 2, 2021 at 6:46 AM
    Mt203
    Mt203 [OP] Member
    I guess I'm asking, to support a constant weight in the back is it beneficial to get the TRD lift/leveling or is it something else I need for the rear end?
    Mmaira2018 likes this.
  3. Jun 2, 2021 at 6:52 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You won't get any added weight support from the TRD lift. You need new leaf springs.
  4. Jun 2, 2021 at 7:10 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Your GVWR won't change by doing anything to modify the suspension. You can modify the suspension to get the truck to sit level when loaded, but you still shouldn't exceed GVWR, at least not on a regular basis. Probably every truck made has been overloaded at times. But to do it all the time is asking for trouble.
    You went from a truck with 1600-1900 lbs payload to a truck with 1000-1300 lbs payload. There is a sticker on the door with the payload of your current truck. Every truck is different based on how they are equipped but most Tacoma's will fall somewhere in the 1000-1300 lb range.
    You're talking about carrying around 500-600 lbs all the time. The truck will do it, but you're not going to be able to pull a trailer or carry any passengers or other cargo in the truck at the same time. When you start adding a 150-200 lb driver and another 150-200 lbs for each additional passenger you'll get to 1000-1300 lbs really fast. Not to mention 300-500 lbs tongue weight from a trailer.
    Just for reference my truck has 1200 lbs payload. My cap weighs 180 lbs, I weigh 220, my wife 140. That leaves me 660 lbs usable payload. I've carried a lot more than that for short trips occasionally. But I wouldn't make a habit of it. If I had I wouldn't have gotten 214,000 trouble free miles so far.
  5. Jun 2, 2021 at 7:23 AM
    Mmaira2018
    Mmaira2018 Well-Known Member
    A leveling kit might fix bro lean but it does nothing to improve the performance of your suspension. In fact, with that constant weight your suspension is going to feel stiffer and harsher off road because your leafs and springs have less down travel available to them since they're already partially compressed due to load. You'll probably want an add a leaf at minimum to correct the constant weight you'll be hauling.
    Furthermore, a leveling kit pushes the stock suspension components beyond their intended geometry, which can lead to failure in off road settings. Plenty of guys run them on daily drivers, but a leveling kit is not recommended for anything that's going to see moderate off road use and beyond.
    rizrox likes this.
  6. Jun 2, 2021 at 9:52 AM
    Mt203
    Mt203 [OP] Member
    I realized after posting this that I was looking in the wrong direction. With a leveling kit it would bring front and rear up, added weight brings rear down, so while the rear may be at the same height as before the weight and leveling kit the front would be a good bit higher. The weight I'm adding that will be constant is a Decked drawer system (200lbs) and a Leer 100xr topper (180lbs). Those will be in or on the truck consistently. So 380lbs in the rear consistently. What will occasionally be in the truck is another 100-150lbs of gear. I like the stock height on the Tacoma so I would like for the truck to ride around that with this load (Topper and Drawer).
  7. Jun 2, 2021 at 10:07 AM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    you're probably going to need an AAL or a full new leaf pack at a minimum.
  8. Jun 2, 2021 at 10:22 AM
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    Just get Firestone air bags.
  9. Jun 2, 2021 at 10:23 AM
    Clearwater Bill
    Billy
    Largo Florida
    If you don't 'need' a lift, don't lift. But get a bit more spring capacity for the rear with new springs.
    Yes, if you unloaded it, it would be jacked up. So save the OE springs to reinstall when you strip down the truck before your next trade in.
    As @Marshall R and others have pointed out, you are already approaching the cusp of truck performance.
    You may be stunned to find that your MPG savings over the Tundra will have about a 25 yr ROI if you leave it loaded up all the time.
    Yes, I exaggerate. A little. But dependent on your annual mileage and what rising fuel costs do, your fuel $ savings won't be exciting.
    hiPSI likes this.
  10. Jun 2, 2021 at 10:59 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Probably not. In my Tundra I get around 18 mpg on highway and around 13-14 mpg around town. Put that up against a Tacoma hauling 500 lbs? Maybe a mpg better.
