Rear Ended - Frame Bent
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mbigpops, Jun 11, 2010.
  1. Jun 11, 2010 at 6:08 PM
    mbigpops
    mbigpops [OP] Well-Known Member
    2017 TRD Sport
    I have an 06 double cab 4 x 4 and was rear-ended two days ago. I am fine. I went under the truck tonight and noticed that the frame is bent on the drivers side near where the class III hitch bracket mounts.
    Is this frame repairable ? If so how ?
  2. Jun 11, 2010 at 6:20 PM
    Richman21
    Richman21 I think therefore I'm a Democrat
    Jeff
    Albuquerque, NM
    09 DC Sport PreRunner
    Hardwire radar detector. Tube steps.
    I had a 2006 that was rear ended and the frame was bent, my insurance company totaled it. I did not have my ball mount in either. They were going to put the body on a new frame, which was going to cost like $15k. Go through your insurance company, not the other drivers. It's called subregation. See my thread over at Toyota Nation.. http://www.toyotanation.com/forum/showthread.php?t=290996&highlight=minor+accident
    They can repair the frame, but they can also put your body on a new frame.
    Pics???
  3. Jun 11, 2010 at 6:31 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Photos would be awesome. Bent frames have gremlins in my limited experience- They aren't every "right" again.
    So I'd want to totaled or the frame replaced unless it is the most minor of bends.
  4. Jun 11, 2010 at 6:32 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    I'm sure you got a police report, and called the insurance company right?
  5. Jun 11, 2010 at 6:46 PM
    peejay
    peejay Yep im that Peejay..
    PJ
    San Diego
    Running a tricked out rzr xp 4
    Rollin a Hemi, and wheelin a sick xp4
    I had an 08 DC 4x4 and got hit on the passenger front side on the freeway which put me into the median at about 45mph. My frame was bent so my insuarance company (allstate) replaced the frame ( it cost 4k). But you have to push the repair shop ( toyota of poway did mine) to replace the frame and not straighten it.
  6. Jun 11, 2010 at 7:20 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Yea, frame bent should be a totaled truck or replacement frame. Pulling/cut n weld is never the same. Sucks, but glad you're alright.
  7. Jun 11, 2010 at 7:25 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    this is why i miss my 2500hd. i got rearended my some ahole in a snow storm he had a little access cab first gen base model 5 lug. He totaled his truck and scratched a little chrome off my ball and broke my 7 pin trailer bracket that was 60% rusted through anyway. Miss that truck...
  8. Jun 12, 2010 at 4:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You may also want to check the frame 'skew'. If you think the frame is bent, then its probably totally skewed also (not good).
    Grab a couple strong magnets, some string, and fishing weights (so to speak).
    The whole idea is to make two plumb-bobs.
    http://en.wikipedia.org/wiki/Plumb-bob
    Attach magnets to a corner of the truck somewhere and the other one at the opposite corner of the truck. Measure the distance. Repeat doing the opposite corners - making sure the plumb bobs are placed in the exact locations. Measure....
    The measurements should be equal.... if they're not, the frame is twisted/skewed. Depending on your insurance company.... but usually, if the cost of a frame replacement PLUS all other costs is approx. 70% of the value of the vehicle = TOTALLED.
  9. Jun 12, 2010 at 9:20 AM
    mbigpops
    2017 TRD Sport
    Everything was done by the book (police, ambulance, insurance).
    Thanks for the insurance tip.
    My son is a mechanical engineer and he says no way they can bend the frame back.
    Here is a picture.
  10. Jun 12, 2010 at 9:27 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah...Concur with Janster. That frame is toast cause it's most likely out of square now.
  11. Dec 5, 2012 at 2:10 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    there are different ways a frame can be damaged, a diamond or body gaps being off is just some time on the frame machine and you'll be fine, kinked frame rail= replaced frame rail, minor bends can be repaired.
    It sounds like the frame is bent at the mounting bolts for the hitch, which could be just a simple repair. Check the bed gaps first. Without pics it is impossible to say if in needs a frame rail, frame time or simply some hammering out.
  12. Dec 5, 2012 at 2:12 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    also there are places in the frame designed to be sectioned, you don't need a full frame replacement unless the damge is a kink beyond a sectionable area (too close to center of vehicle)
