Rear Engine Mount(tranny mount)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballataco, Sep 30, 2019.
  1. Sep 30, 2019 at 4:47 PM
    ballataco
    ballataco [OP] Member
    Blake
    2009 Tacoma Prerunner
    Swayaway 2.5 Maxtrac spindles Aux lights TC uppers Fox 2.0 Bfg k02 Bunch of little things
    I replaced the transmission mount a while ago because the OEM was shot, rubber was not attached causing transmission to shake. Doesn’t help I have axle wrap. I replaced it using an Oreilly’s Mount and it did the same thing. Rubber came separated. When I installed the new one it was very hard to align and ended up putting a lot of pressure on the tranny mount. Would a solid transmission mount( rear engine mount) be wise or should I look into fabricating a relocation plate. Transmission sits a little further than where the mount is on the subframe causing a lot of tension on the rubber in the mount.
    :bowdown: Thank you TW
  2. Sep 30, 2019 at 5:14 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    You can't use a solid trans mount unless you also use solid engine mounts - unless you want to break your tailhousing.
    ballataco[OP] likes this.
  3. Sep 30, 2019 at 7:50 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Get a proper OEM Mount and install it properly. Or you have something bent out of place if it is putting that much force on the rubber mount.
  4. Sep 30, 2019 at 10:05 PM
    ballataco
    Blake
    Definitely makes sense, do you know of anyone running all solid mounts. I bet that feels wonderful......
  5. Sep 30, 2019 at 10:10 PM
    ballataco
    Blake
    Thanks for the Reply! Something is out of place, both mounts I have put in have done the same thing, OEM and oreillys. When I slowly hit the brakes I can hear it torquing the subframe member. I will add pictures later. I was really just seeing if it was a common problem. I guess it’s just my special taco problems:frusty:
  6. Oct 1, 2019 at 2:13 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No, that would suck really hard!
  7. Oct 1, 2019 at 2:17 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Was it ever in a wreck?
    It is fixable regardless, it could even be as simple as a homemade alignment adapter plate.
  8. Oct 1, 2019 at 2:20 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Something is damaged,I would take the truck to a driveline shop and see what they say.
    ballataco[OP] and Jimmyh like this.
  9. Oct 1, 2019 at 2:24 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    might be as simple as loosening motor mounts and allowing the bolts to slide a smidge within the holes.
    nagorb and ballataco[OP] like this.
