Rear floats after lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoguy05, Aug 11, 2021.
  1. Aug 11, 2021 at 9:50 AM
    Tacoguy05
    Tacoguy05 [OP] Active Member
    2018 TRD Sport
    Does anyone else have issues with vibration on their long bed after a lift. Or are blocks prone to give it a floating/vibe sensation. I’ve seen so many posts where people put 3/2 lifts and no issues. I have a 1.5” tapered rear block and it feels like I have a slight vibration. I understand it won’t ride like stock.
    At this point can’t tell if it’s the northeast roads or the stiff ride.
    Any thoughts?
  2. Aug 11, 2021 at 9:52 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Did you do the carrier bearing drop
  3. Aug 11, 2021 at 9:53 AM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    Have to ask...
  4. Aug 11, 2021 at 9:56 AM
    Tacoguy05
    2018 TRD Sport
    I did and it doesn’t feel much different. This is my first lifted truck so it’s hard to know if this how it is supposed to ride.
    Hard to tell if it’s a vibe or our roads in upstate NY.
  5. Aug 11, 2021 at 9:57 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    yes, you will, or might get vibes. it could be your axle vibrating so you need to replace your needle bearing. the way to test that is drive the truck and put it into 4x4. if the vibes go away, then its your needle bearing.
    other reason for vibes is that you changed the angle of your driveshaft. so have to find a way to fix that, get a single piece driveshaft made, or live with it.
    im lifted about 3" front 2" rear and i have vibes that come and go....i just live with it. eventually if it bothers me too much, ill install a one piece driveshaft.
    hyrule_trd likes this.
  6. Aug 11, 2021 at 9:59 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    What’s your psi and alignment like? If you feel the vibes at lower speeds, try turning on 4WD and see if they go away. If they do it needle bearing.
    You might need to check and mess with drive angles as well.
  7. Aug 11, 2021 at 9:59 AM
    Tacoguy05
    2018 TRD Sport
    I did do the tapered 1.5” block from American Automotive.
    Do you know who else sells the 1.5” blocks?
  8. Aug 11, 2021 at 9:59 AM
    tw0leftskis
    0xApes
    Meta Verse
    How are your tires wear pattern? Cupping feathering?
  9. Aug 11, 2021 at 10:02 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Im in the same boat. I’ve messed with 3° shims in the back and adding washers and spacers to the carrier bearing. After much trial and error, I removed the shims and have about 10 stainless fender washers at the carrier bearing. I only get vibes sometimes but if I do they are at the same speed 53-54 indicated mph.
  10. Aug 11, 2021 at 10:03 AM
    Tacoguy05
    2018 TRD Sport
    The needle bearing has been replaced when I had the Eibach Pro Shocks installed, and I’m scheduled for and alignment this week. I’ll check the tire pressure and see what that is at.
    I’m debating whether to go to the Eibach 1” block.
  11. Aug 11, 2021 at 10:07 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    I’ll say when I tried the recommended (40) psi with my 255/85/16 ST Maxx with oem UCAs, it felt like I was driving a boat. I didn’t like it at all. Lowering the psi to 32 has a much better feel, even when I had the stock UCAs. The SPC UCAs and a good alignment helped as well.
    coma toy likes this.
  12. Aug 11, 2021 at 10:08 AM
    Tacoguy05
    2018 TRD Sport
    No cupping or feathering. This block was recently installed. I’ll check that too.
  13. Aug 11, 2021 at 11:08 AM
    coma toy
    coma toy Off Road Taco
    I really wanted a 3/2 Lift, but after much homework, found the 2/1 Lift to be the most reliable. Even with just a 1" rear block, my rear end feels the same as it did before the lift.
  14. Aug 11, 2021 at 11:44 AM
    tw0leftskis
    0xApes
    Meta Verse
    Im running Dakar HD leaf pack
