Rear Gear Questions
Discussion in '5 Lug' started by Bosmob, Jan 10, 2013.
  1. Jan 10, 2013 at 10:09 PM
    Bosmob
    Bosmob [OP] Well-Known Member
    Kevin
    San Diego, CA
    '11 Access Cab SR5 I4 4AT
    Fat Bob's 2.75" front spacers Magnaflow Muffler Doug Thorley Header ImMrYo Mirror Bracket
    I want to regear my 5 lug. It's a 2011 with the automatic. I'm running 31's right now but am going to up it to 33's pretty soon.
    What final drive ratio do I have?
    Who sells rear gears for my truck?
  2. Jan 10, 2013 at 10:56 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    i believe you ave 3.73 for 33s you would probably need 4.56 you can get them from east coast gear supply
  3. Jan 10, 2013 at 11:18 PM
    Bosmob
    Kevin
    San Diego, CA
    4.56's?
    That pretty damn low. I'm just wondering how did you come up with that number?
  4. Jan 10, 2013 at 11:29 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    most guys run that for 33s. 4.10 for 31 4.56 for 33 and 4.88 for 35
  5. Jan 11, 2013 at 6:00 AM
    Bosmob
    Kevin
    San Diego, CA
    Even for street driving? Do they have 5 speeds or are they 4 speeds like mine?
  6. Jan 11, 2013 at 9:03 AM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    I would contact ecgs first. See what they recommend for your truck. But i think 4.10 isnt enough for 33s
  7. Mar 5, 2013 at 8:06 PM
    MIAtaco
    MIAtaco Well-Known Member
    Brian
    Miami FL
    2010 tacoma base lifted
    2.75" front lift 2.5" rear, pro comp es3000 rear shocks w/ orange shock boots, custom exhaust, k&n cold air intake, 20" led light bar behind grill, aftermarket grill, T-rex3 eyelids, pioneer HD radio
    stock 4cyl 2nd gens have either 3.10 or 3.30 gears so i say 4.10 or 4.33 would be better
  8. Mar 7, 2013 at 9:13 PM
    melliott15
    melliott15 Active Member
    Marty
    Fort Worth
    2016 Barcelona red Dbcb 2.7
    none
    Your rear gear is a 3.58 with the auto tranny, the manual tranny is a 3.31. If you want a stock power feel then go for the 4.10 as previously stated, more power go with the 4.56.
  9. Mar 8, 2013 at 6:03 AM
    fender104
    fender104 Active Member
    stanley
    Camp Lejeune
    11 Regular Cab 2wd
    Tint, Boston Speaker, Fog Lights, Tool Box,Debadged, Black Box mod, XRunner Rims, nitto terra grapplers 285/60/18/, Intermittent wipers,Scan Guage, front HD bilsteins, rear trd offroad bilsteins, Fat bobs lift
    I'm also considering re-gearing. What is the trade of on getting 4.56 over 4.10's?
  10. Mar 8, 2013 at 9:18 PM
    melliott15
    Marty
    Fort Worth
    none
    If you go with 4.10 you might see an increase in fuel mileage and a definite increase in power. With a 5 speed, 285/60/18 and 4.10 your RPM at 65 will be about 2200 to 2300, same setup auto trans RPM will be around 1900 to 2000. With the 4.56 you will see a power increase and the MPG could stay about the same or decrease. Same above setup 4.56 5 speed RPM will be around 2500 to 2600 and the auto would be around 2200 to 2300.
