Rear gear really necessary for 285’s ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 71tattooguy, Dec 27, 2019.
  1. Dec 27, 2019 at 11:35 AM
    71tattooguy
    71tattooguy [OP] Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Debating 265’s or 285’s. Light off-roading trails and camping. I don’t load truck up with real heavy loads. So is re gearing necessary? Or should I just do 265/75/16. Call it done?
    Wixo likes this.
  2. Dec 27, 2019 at 12:08 PM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Changing the gears is not a mandatory thing. People all over the world get lifted trucks and larger tires and never touch the axles. Just understand a larger tire is harder for the drive train to turn. Will it be noticeable enough to you to be unhappy? That’s to each individual to decide by feel.
    Also with larger tires means a larger strain on the transmission. Once again only the person driving the truck before and after the tire change will notice the difference but there will likely be more gear shifting in the higher gears with a larger tire and stock everything else.
    Add the larger tires if you want then go from there. If money isn’t an issue go all out :)
  3. Dec 27, 2019 at 12:36 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Think I will just go up a tire size and call it done.265/75/16
    Tullie D and nat103 like this.
  4. Dec 27, 2019 at 1:08 PM
    newdles
    Achmed
    Odd because I have a 2019 trd off road and mine came stock with that size. But still plenty big enough for 99% of most people’s needs. I was going to lift and put 285’s on but that will be a much later day if I do it. Twin turbo setup sounds so much more worthy for the money :)
  5. Dec 27, 2019 at 1:20 PM
    714reyesj
    714reyesj Well-Known Member
    Danny
    Orange County, CA
    2017 TRD Off-Road 4x4
    Go 285s trust me. I started by upgrading to 265/75s and it was great for a while but once my lift was done, the truck looks so much better with 285s. In regard to whether re-gearing is needed for 285s, I was super worried that the truck was going to feel extremely sluggish with that size tire and that I would have to re-gear but to be honest with you, I think the truck handles and drives just fine with 285s. Any bigger and id say it is a must.
    If you got the cash for it and are willing to do the other necessary steps to fit 285s (lift/CMC) then go the 285 route. I have a buddy that is thinking of re-gearing but that is because he tows a lot.
    synaps3 and 71tattooguy[OP] like this.
  6. Dec 27, 2019 at 1:37 PM
    Sirpopeington
    Sirpopeington Well-Known Member
    17' TRD Off-road 4x4
    From what I understand is that if you regear for 285’s you will be higher than you need to be.
    I have 285s and haven’t seen much in terms of power loss and fuel mpg drop. You’ll be fine with the 33s
  7. Dec 27, 2019 at 1:37 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    I’m lifted now just debating on tire size when I’m ready. That being said. Think I’m over thinking it lol. Sounds like your good with the set up
  8. Dec 27, 2019 at 1:44 PM
    714reyesj
    Danny
    Orange County, CA
    I went 265s first because I got tires before lift. After installing my KANGS 285s were a must. If you regret anything, its probably that you went small and not that you went big.
  9. Dec 27, 2019 at 1:47 PM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Voting: 285 no regear!
    edgarcg2 and 71tattooguy[OP] like this.
  10. Dec 27, 2019 at 1:51 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    285s and no regear for me. Seems fine. With the auto the engine spins high during climbs but it probably would anyways. Even 33s look small to me on these trucks, couldn't imagine going back to stock. Fuel economy will go down a decent amount but it's a Tacoma not a prius so it is what it is.
    NWTacoTime and 71tattooguy[OP] like this.
  11. Dec 27, 2019 at 1:53 PM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Another 285 with no re-gear vote. I tow all the time, too. No noticeable power loss. Slight MPG hit but otherwise I think it's not worth the money to re-gear.
  12. Dec 27, 2019 at 2:35 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Sounds good thanks a lot for your input. I’m not worried about mpg’s either. It’s a truck
  13. Dec 27, 2019 at 2:56 PM
    SAPR53
    SAPR53 Well-Known Member
    2019 TRD Offroad
    King 2.5" Ext resi with compress adjust Front and Rear ICON RXT Leafs ICON Tubular Delta Joint UCAs Xenon HD LED Low Beam Swap Baja Sports Wide Cornering Fogs Interior LED AVS In-Channel Extang Solid Fold 2.0 Tonneau
    Living in San Diego the constant gear hunting up all the hills is maddening. I just went from 265 to 285s and a regear to 5.29s couldn’t be happier. MPG went up because the truck is no longer constant shifting up hills it just holds and glides up the hill.
  14. Dec 27, 2019 at 3:02 PM
    Chunk
    2016 DCSB OR
    Baby Ruth
    Did you OVtune first? Just to try that option?! I wouldn’t have regear until I explored all other avenues! Not bashing, just ask in’!
  15. Dec 27, 2019 at 3:03 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Not necessary but regearing makes the truck drive a heck of a lot better. It should have came with 4.88s from the factory.
    strongrob, Chunk and 71tattooguy[OP] like this.
  16. Dec 27, 2019 at 3:09 PM
    Sdshooter
    Sdshooter Well-Known Member
    San Diego
    2017 TRD Off Road 4x4 Quicksand
    Kings on all four Pelfreybilt bumpers Dakar Leafs other crap
    No need to regear with 285’s. I’m running 35’s and I haven’t regeared yet. Eventually I will get 5.29’s but I really am in no rush because of the way the truck drives. It feels a little sluggish with all the armor and larger tires but nothing that makes me want to regear right now.
  17. Dec 27, 2019 at 4:20 PM
    newdles
    Achmed
    If I were to change the gears in the truck after going to 285 from 265, I would personally try to obtain the 4.30 gears from the manual trans Tacoma. Going up to 285 from 265 makes going from 3.93 to 4.88 a bit overkill.
  18. Dec 27, 2019 at 5:29 PM
    0311K1LL
    0311K1LL The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    The truck needs to be regeared stock lol. 2.7 and 3.5 doesn’t matter , the 6 speed auto sucks. Even with the updates and tsb it doesn’t solve it.
    SAPR53 likes this.
  19. Dec 27, 2019 at 6:17 PM
    Bascoma
    Bascoma I smell dog poop.....
    Jake
    Deep Creek VA
    S/C 2017 OR MT
    Magnuson Supercharger TRD Bilstein 6112/5610 w/ Head Strong 3 leaf AAL URD Mark 2 Y Pipe OV Tuned (pre Magnuson install) TRD Intake TRD Exhaust TRD Skid Plate TRD Shift Knob Leer 100XR Subaru Kicker Tweeters Toyota Bed Mat Kicker CS Door Speakers Kicker H8S Hideaway Sub Toyota All Weather Floor Liners Caliraised LED Bumper Light Bar De Badged Tint Console Organizer CMC with BAMF Plates 17” SCS Ray 10’s 285/70r17 Ridge Grapplers Faux PRO Grille Hondo Radio Knobs Accumulator Delete Mod URD Short Throw Shifter JLT Oil Separator MESO Ultimate Turn Signals MESO Map Lights MESO V2 Dual Color Dome Light RC Seat Covers Stoptech Slotted Rotors Sport Pads and Stainless Brake Hoses
    I’m glad to see all the responses voting no!
  20. Dec 27, 2019 at 7:54 PM
    SAPR53
    2019 TRD Offroad
    I’ve had ovtune since I bought the truck. Thanks for the suggestion.
