Rear Glass: slider v. solid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wiggler, Jul 27, 2020.
  1. Aug 1, 2020 at 9:58 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    That is odd. When I searched for replacement glass a year or two ago I was told by a couple of glass places you can't get the glass separately. That on a Tacoma the slider frame is built around the glass and would be ruined if you try to replace just the glass.
    Quick search here:
    https://www.tacomaworld.com/threads/replacing-single-rear-sliding-window.313159/
  2. Aug 1, 2020 at 10:14 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    No one changes just the glass. The frame comes with the glass on a slider.
  3. Aug 1, 2020 at 10:46 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I have a 2014 Tacoma with 103,000 miles on it. Number of times I've used (or wanted to use) the slider? Zero. If mine ever needs replacement, it will be with the one piece glass.
    fatfurious2 likes this.
  4. Aug 1, 2020 at 10:51 AM
    Doublecross
    Doublecross Well-Known Member
    Robbie
    New york
    Work in progress
    ARE cap, wade inchannel vent visors, weathertec floor mats, ranch hand grill guard, tuffy security boxes in bed, lockable tailgate handle. Still have stuff that needs to be installed and still have stuff ordered lol.
    it would be easier to put rear defroster on a 1 piece :cheers:
  5. Aug 4, 2020 at 12:19 AM
    wiggler
    wiggler [OP] Well-Known Member
    HILO
    2013 OR AC 6MT & 1998 4Runner sr5 auto
    Well going with the one piece, will get installed next week.
    fatfurious2, B Dog and davidstacoma like this.
  6. Aug 4, 2020 at 1:22 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I'm thinking about pulling my slider out in favor of a one piece.
    Part of the frame of the slider is damaged from the PO, he had a toolbox in the bed and it was rubbing on the frame of the window.
    I priced out both and the sliders are super expensive.
  7. Aug 4, 2020 at 5:28 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    I didn't use the slider in my Access cab at all last summer. Kinda a PITA to deal with. I've had sliders in reg cab trucks before. FF to this summer, I've used the shit out of the slider, the air flow is perfect compared to the tornado effect encountered in my previous reg cab trucks. Great when the temps are not quite up to a/c territory. If it broke, I'd replace it with another slider. For those who run a/c or climate control constantly, I could understand the opposite. But I like me some fresh air if it ain't sweltering hot/humid out!
    Spare Parts likes this.
  8. Aug 4, 2020 at 11:59 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    I use my slider whenever I have too haul long 2x4s or such,so I think you should get another slider.
    koditten likes this.
  9. Aug 5, 2020 at 1:35 PM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I have a cap, so I don't really open the slider window anymore. But before I had the cap, I used it often and loved it - it's the only thing I miss about having the cap.
    lowmower likes this.
  10. Aug 11, 2020 at 9:55 PM
    wiggler
    HILO
    9397A025-B2FB-4984-9E9A-1B3B7934B41D.jpg So glad I went with the one piece, looks better and the rear view while driving or reversing is 100x better.
    lowmower, not_nick and koditten like this.
  11. Aug 11, 2020 at 9:57 PM
    koditten
    Kirk
    Central Michigan
    I suppose I have to like that post:)
  12. May 21, 2025 at 4:21 PM
    motorgoat
    motorgoat Active Member
    Chesapeake, Virginia
    2010 Prerunner
    How much did it cost you (parts and labor)? Did you go with OEM?
  13. May 21, 2025 at 6:09 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [ED] Entune Audio+ [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    I have the slider on my double-cab. I have only had it open a few times over the last 3 years since I got the truck. Even so, I would probably replace it with same if it ever broke. With the driver's window down some, ventilation is great when also I open one of the rear door windows about 1/3 of the way. Same for the when the slider is open.
    If I could reach the slider from the front to open it or if it was remotely powered, I would probably have it open most of the time during the summer instead of running the a/c.
  14. May 22, 2025 at 5:15 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    I open the slider periodically to get some air flowing through the cab. In fact, I specifically avoided buying a truck with a solid rear window because I knew I'd use it.
